MX-M904 with flasing power indicator
  • axyun
    • Aug 2007
    • 1323
    Custome called saying issues with finisher , jamming etc. When stopped by this morning there was no display. The power indicator is flashing.
    Have never serviced this machine. Tried pressing home button twice to begin service mode but no change. Any help here is appreciated. Frank Action Photocopy
  • driving lots of miles
    • Jun 2016
    • 397
    Re: MX-M904 with flasing power indicator
    SD Card or MSATA or maybe Hard Drive?
    • axyun
      • Aug 2007
      • 1323
      i may have to call customer and pass on this call. Thank you
      • bilyahn
        • Dec 2006
        • 1470
        Are there fans running?
        If they are running then it is probably the mSATA as previously mentioned.
        If not then it is one of the DC PWBs, probably the Sub DC PWB located on the left side of the copier next to the finisher. Just had this happen a couple of weeks ago. One of the soldered in fuses had blown causing this condition....
        Good luck.
        Bil
        • mojorolla
          The Wolf
          • 2583
          Unplug the HDD and boot up the machine. If it comes to an E7-03, the HDD is the issue.
          Additionally, you can look at the MFP board itself and look for the illuminated LEDs, I believe this model had 4 which should be lit.
          • axyun
            • Aug 2007
            • 1323
            Thank bilyahn + mojorolla for your info. As I had no experience on this machine and have noit expertise I told customer to look for someone with experience on this model. Frank
            • bilyahn
              • Dec 2006
              • 1470
              IDK what I was thinking, this model does NOT have an mSATA but an SD card and program ROM. LOL Mojorolla is correct about the lights. In the condition I stated none of the LED lights were lit.
              Sorry for the mis-information.
              Bil
              • repn1999
                • May 2010
                • 310
                Bil
                DC Power supply most likely. Same symptom happens to Polaris machines and is the same fix....
                • El Papa
                  • Nov 2015
                  • 27
                  Got the same issue. One of our engineers attended site with the device stalled in the middle of a print job. Removed HDD and E7-03 error.
                  He requested a HDD (1TB SATA) and I returned to fit.
                  Replaced HDD and screen is dead with blinking LED on op panel. Checked controller and all four LEDs are illuminated.
                  Installed old HDD to see if issue with new HDD and issue still the same. All fans are running.
                  This is the only MFD of this type we have in Field and up till now it's caused no issue.
                  Any info on fix would be appreciated or a start point. Does this MFD boot via the HDD or are we looking at a faulty DIMM?
                  • copierdude1114
                    • Dec 2015
                    • 29
                    I would almost guarantee it's a faulty SD card
                    • El Papa
                      • Nov 2015
                      • 27
                      ***Update***
                      Issue was with 1TB HDD.
