Customer ordered toner for AR-M237. " Change toner cartridge" was in display. I had a recycled cartridge with chip from Static Control. I have used their AR-M237 chip for another customer which worked fine.
Got message "check toner cartridge". I put the chip on the empty cartridge to see what I would get and got same thing ( "check toner cartridge".
I assumed there was a problem with chip. I came back to customer's office with 2 OEM cartridges(AR-M310NT)as customer now wanted OEM and an extra.
I installed cartridge and it went into ready. I made several copies then left. Customer called an hour later with a U2-40 on OEM cartridge. I instructed customer to try simulation 16 but each time it reset it would come back when customer made a copy and paper would jam.
I told customer to open other new cartridge and change. When customer did this he got the "check toner cartridge" message on the second OEM cartridge.
I have to go back tomorrow and I guess I'll check contact in back. Any suggestion you can make would be appreciated very much as I am not sure what to do and beginning to panic here. Fran/ActionPhotocopy
