Sharp AR-M205
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    [Misc] Sharp AR-M205
    Hello all friends l found driver for Sharp AR-M205 ...cause l connected my laptop by usb but no connection ..oh l use windows 10 64 bit ..thank you advance .
    BEST TECHNICIAN . NICE PEOPLE .
    • 23010
    Re: Sharp AR-M205
    I seem to recall that this model required a print option, not on very many machines. I'll check tomorrow.
    You know that this machine is verging on 15 years old? It seems to me that you time is better spent on something a little more recent. =^..^=
      • 23010
      Re: Sharp AR-M205
      From what I've read, with the standard equipment you can print via USB1 via a GDI driver (assuming that you can find a compatible driver). Does your PC communicate via USB1?
      With the AR-EB7 option you can print via USB2 and TCP/IP in PCL (assuming that you can find a compatible driver).
      If you add the AR-PK1/N PS3 option to the AR-EB7 option you can print via PostScript (assuming that you can find a compatible driver).
      I would be very surprised if you were able to locate any of these options, and if it was cost effective to buy them for your 15 year old MFP. =^..^=
      • boutn
        • Jun 2016
        • 552
        Re: Sharp AR-M205
        AR-M205 won't print via usb on WIN10 if you dont have the optional network box...
        And even then...no drivers available.
        It does work when you have the network option, and use the MXM182 driver instead.
