Office 365 scan to email
  • davebtech
    • Apr 2015
    • 169
    Anyone get any ce-00 codes yet from customers trying to scan to email? Anyone seen the firmware yet for 1.2 for mxm 264,314,354 ??
  • r3d343420
    • Aug 2012
    • 55
    Re: Office 365 scan to email
    We have had that problem
    Try to set the SSL Level in security settings from low to high
    Security settings->SSL settings->drop down box from low to high and hit submit
    • Toner Boy
      • Aug 2007
      • 349
      Tried it on MX-4110N just now, failed. SSL security set to high.
      This is popping up everywhere today...please post if you figure it out!
      • Grebom
        • Oct 2012
        • 5
        We have tried updating the firmware on a MX-4141N to 04.00.R2.C0 as suggested in TT-051418_1 and are still having the issue.
        Any update would be appreciated as we have several customers experiencing the issue today. It seems to be intermittent as well during our testing locally.
        • 1090tech
          • Jan 2018
          • 8
          Having the same problem, will post here if I discover anything useful.
          • 1090tech
            • Jan 2018
            • 8
            • Grebom
              • Oct 2012
              • 5
              Thanks 109tech! a coworker also found this newly published youtube video this morning that indicates the same thing. We have tested it and it appears to be working.
              • mttech
                • Mar 2014
                • 127
                I just noticed on the Sharp IDNC homepage they have a banner that says they are aware of problems scanning with Office 365 and are working on the solution and will update. Not sure if that is good news or not. Just passing it along.
                • mansart
                  • 851
                  smtp O365.pdf
                  • davebtech
                    • Apr 2015
                    • 169
                    Originally posted by mansart
                    [ATTACH]40661[/ATTACH]
                    Great post thanks! Worked on mxm 354 this morning
                    • oeshuron
                      • May 2008
                      • 259
                      I recently had issues with one not working and had to enter in the Sender information. However, I couldn't use the < > brackets as specified in a previous bulletin otherwise it would error out. I just used the email address by itself.
