ARC 260M Magenta stripes
  • nmfaxman
    • 1702
    Making magenta stripes front to rear.
    Looked like mag roller but I replaced unit and marks were still there.
    Drum looks good.
    Another company had it in their shop for a month buy never said what the problem was.
    It is intermittent in density but the spacing is the same.
    Bad HVT or bias terminal?
  • ZOOTECH
    Senior member of CRS
    • 3375
    More likely the drive gear for the toner box located on the rear frame.
    • DavePo
      • Jul 2008
      • 303
      ngerh1530fcz4 replace all four
      • NCArt
        Mountain Tech
        • May 2008
        • 81
        And they are real fun to replace...thank goodness I have skinny arms
        • nmfaxman
          • 1702
          Makes sense.
          Thanks guys.
          • nmfaxman
            • 1702
            That was the fix. I taped a thin file to a long screwdriver and popped out the gear with a curved set of hemostats.
            Locked the gear on with a larger set of hemos and popped it back on with a socket screwdiver with no bit.
            Took me 45 minute for all the gears.
            Thanks for the info.
