MX-M753N POD_N1
  • xring1958
    • 166
    [Jamming] MX-M753N POD_N1
    I have a 753 that is jamming every 70 to 80 copies. only seems to happen when doing multiple copies ( Larger Runs) page stops before fuser and has a fold in it with corners bent. Fuser drive unit doesn't look bad but I have one on order. It reminds me of the jams you get on MX-5100s that have a broken transfer belt Gear. Any suggestions are appreciated. It is a pretty long dive so I'd like to be ready for most probable possibilities.
  • romang
    • Aug 2011
    • 72
    Re: MX-M753N POD_N1
    The drive unit should take care of it. Thats a common problem with that model. There is a bulletin for it.
    • copiertec
      • Jan 2016
      • 2205
      Re: MX-M753N POD_N1
      TT-121313_3 Pod 1 and 2 jams.pdf
      You're on the right track, I hope this helps.
      • xring1958
        • 166
        Re: MX-M753N POD_N1
        I always like to leave a final outcome when I post on this Forum.
        I ordered the fuser drive unit and installed it yesterday.
        Ran 100 copies jammed at about 87 exactly like it did before same folds same dogears.
        I then replaced the Fuser unit and ran over 100 with no issues.
        I guess I will hear from customer if issue continues ( I hate intermittant problems)
        Thanks for all of the responses
        • bigdaddyooo
          • Dec 2014
          • 211
          Re: MX-M753N POD_N1
          The only dog earring I've seen is when the exit guide ribs on the fuser cake up with toner causing jamming and dog ears. Just clean off the ribs and problem should be resolved.
          Are you the police? "No ma'am, were musicians"
          • yorky
            • Jan 2013
            • 6
            Re: MX-M753N POD_N1
            Had a similar scenario on one of our machines intermittent duplex jams (POD1) tried the drive/fuser rebuild/transfer with no success, replaced the fuser unit and the fault was resolved
            hope you get the same result mate
            all the best
            Yorky
