Sharp 2610 curly paper
  • Jack79
    • Jul 2014
    • 312
    Hi friends
    Sharp 2610n curls the paper, It is very visible on A3 paper. I have a few of them with the same issue.
    I noticed that problem is with the delivery unit. When I swap it paper comes out fine.
    Does anybody know what case the problem? Both delivery units looks the same and I cannot understand where is the problem.
    I hope you experienced the same problem before and know the solution.
    Thank you in advance.
    Jack
  • r3d343420
    • Aug 2012
    • 55
    Re: Sharp 2610 curly paper
    Do the delivery units both have the foam rollers attached?
    • Jack79
      • Jul 2014
      • 312
      No they don't. I believe that delivery sponges could help but both units do not have them and one works fine. If I good remember they should be installed next to plastic rollers (where spring is attached) but nothing is there.
      • OlliK1969
        • Nov 2016
        • 311
        How old is the fusing unit?
        Have had the same problem 2 times and change the pressure roller
        • r3d343420
          • Aug 2012
          • 55
          Interesting. I have had this problem when the foam rollers are removed, but it always goes away when I reinstall them.
          • mansart
            • 852
            PAPER CURL ADJUSTMENTS.pdf
            • Jack79
              • Jul 2014
              • 312
              I have installed both delivery units to the same machine so it cannot be fuser related issue because one delivery unit works fine and the second curl paper.
              • Jack79
                • Jul 2014
                • 312
                Yes it is very interesting. I believe these rollers can solve the problem however I do not have them and local dealers cannot get them too.
                Do you know where can I purchase them?
                Anyway I cannot findo out why one unit works fine even without foam rollers.
                • repn1999
                  • May 2010
                  • 310
                  check your fuser. sharp made a modification in the fuser and changed the pressure roller inside the belt from a orange one to a newer brown one. they changed it on all aries1 virgo1 and polaris machines for the same reason. sometimes paper will curk behind the fuser belt on the bigger machines also.
                  • Gareth Pegg
                    • Oct 2018
                    • 5
                    Check the bar that runs across the face of the 1st post fuser delivery unit as these warp under the heat and with uneven pressure comes paper issues. There is mileage as others have said too in fitting the exit unit foam rollers.
                    Good Luck
                    Gareth
                    • Jack79
                      • Jul 2014
                      • 312
                      Good Luck
                      Gareth
                      Gareth do you mean the unit from picture below? I found out that this unit makes a problem. What bar do you mean (metal bar with 4 gray rollers?)
                      Thanks in advance.
                      • lky1978
                        • Mar 2009
                        • 483
                        [ATTACH=CONFIG]41008[/ATTACH]
                        Thanks in advance.
                        try to change the grey roller with steel bar
                        • mojorolla
                          The Wolf
                          • 2627
                          Most Sharps have foam roller inserts on the delivery unit white rollers. Over time, the diameter shrinks from wear and severe paper curl can occur.
                          Newer Sharps have these removed for exit options like paper passes and punch units. If it is just an exit tray, check the foam rollers.
                          • Jack79
                            • Jul 2014
                            • 312
                            Hi Yes I was wrong saying there are no foam rollers. I was thinking about unit from the picture. Apologise for that.
                            When I swap unit from the picture problem gone but I would like to know what exactly cause this issue.
                            I am still not sure what grey roller (part number would be helpful) should I replaced. From the picture I can see 4xrollers on metal bar. The unit from the picture is located above fuser.
                            • ntbann
                              • Jan 2012
                              • 628
                              NROLR1869FCZZ. I have had to change this roller on 465s for toner build up on fuser guide. The diameter gets smaller causing the roller to spin too fast.
