SHARP AR-1118 Firmware
  • vlad_
    • Jul 2008
    • 98
    Hello. The help is necessary. Urgently it is required Firmware (file DWL).
    thanks a lot.
  • bilyahn
    • Dec 2006
    • 1470
    Do you have an equivalent machine. There is no reference to an AR 1118 copier in Sharpnet.
    • vlad_
      • Jul 2008
      • 98
      The equivalent is. But chip a cartridge then will not work.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1878
        Here is the firmware for the equivalent US model AR-M160. Not sure if it's the same, so use at your own risk.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • vlad_
          • Jul 2008
          • 98
          Thanks Tmaged. It firmware for series Pegasus.160-205 For market USA?
          Very much I ask, to lay out the version for AR-5316-5320 USA I with the big desire I will make experiments and with other versions firmware from the list. Email: vlad@velnet.ru
          • MSHADroo
            • Mar 2008
            • 13
            Firmware Sharp
            hi
            i want newest firmware for sharp copier series like 5316/5320/1118j/m205/m160/122e and 5127
            can you help me?
            • tmaged
              • Oct 2008
              • 1878
              Originally posted by MSHADroo
              hi
              can you help me?
              The firmware above is the latest for the US market for the AR-M160.
              Hope that helps !
              -Tony
              www.dtios.com
              • MSHADroo
                • Mar 2008
                • 13
                thanks!
                for other models?????
                • vlad_
                  • Jul 2008
                  • 98
                  To each region there correspond certain programs and cartridges. Error F2-04 is possible
                  I did experiments with chips different regions
                  • Saberi1534
                    • May 2024
                    • 1
                    تشکر از کمک شما
