Ar-m207 dpx top paper jams only when duplex coping
  • xeroxsharp
    • Nov 2008
    • 270
    I do not have any ideas anymore.pleas help.
  • vlad_
    • Jul 2008
    • 98
    Was such at me on AR-M205 Has cured easing of springs MSPRT0141GCA1 FU PSV spring FU PSV spring in block Side door unit. Sheets before shaft of synchronisation NROLP0032QSZ2 PS trnsport roller jammed
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      Have you tried the sensor over the top of the fuser? Have you run it in aging mode (with all sensors disabled)? The duplex in these is pretty simple, it should be pretty easy to figure out. Is it intermittent or does it jam every time you duplex?
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • xeroxsharp
        • Nov 2008
        • 270
        Thanks anyway,but I know about this from AR 235 model. Here I have
        intermittent jams with some noise from post fusser tranport drive belt.
        I allredy made some adjastment,replaced tranport motor and belt,replaced one way clutch-gear,but I still do not have normal duplex copyng (100 two-sided,2-5 jams evrytime with noise).The problem is realy big because it is on 3 mashines at the same customer.
        • NCArt
          Mountain Tech
          • May 2008
          • 81
          A silly question.....is the paper size properly identified in the machine? ie A4 or 8 1/2 x 11 ??
          • oldrn
            • 166
            Have you tested the duplex clutch with Sim 9 sub 1 & 2? This should help narrow down the cause. I am assuming the noise is from the duplex clutch as the paper direction is reversed. When testing with paper, is the jammed paper showing damage like it is running into something?
            • xeroxsharp
              • Nov 2008
              • 270
              Anybody ever changed this spring? MSPRC1315FCZ1 - CLUTCH SPRING A ( servis manual arm205).It is almost inposible,that all three springs are wrong.
              • eng_nsour
                • Nov 2008
                • 10
                hi
                hi man,
                plz where ur question? we don't understand it? details plz
                • xeroxsharp
                  • Nov 2008
                  • 270
                  Originally posted by eng_nsour
                  hi man,
                  Sorry eng_nsour, I do not belive that duplex forward-reverse spring on inverter transport is not OK. Did anybody ever change this spring? I hope the question is ok.
