MX-M753N POD_N1 Revisited
+ More Options
Posts
  • xring1958
    • 166
    At the end of September I posted a question about a 753 that was Jamming right before the fuser with a Pod1_N Jam Code.
    It was suggested that I replace the fuser drive unit and that was a common issue with these units.
    I did so but the problem remained the same. After that I had one of our Techs suggest I replace the Fuser unit. Since the paper was not entering the fuser I didn't see how that would help but I replaced it. It seemed to take care of the problem. I ran a few hundred copies with no issues.
    I now seem to be having the same problem again. There are very few copies on the new fuser so I doubt it is the issue.
    I made sure all the sensors were clean cleaned all transport rollers and registration rollers. The machine runs fine in letter R mode and Legal.
    The letter standard sizes stop right before the fuser entrance the lead edge has a slight dent about an inch and a half long and the paper is folded about 1/3 of the way down the 8 1/2 inch side Page is transferred. I don't see any hard dents in page like I would expect if drum PO finger grabbed it and I never find them stuck under Drum PO Finger. Next Step for me is Door transport assembly and Maybe a drum unit. If any of you can narrow this down all possible solutions are appreciated
  • daileyrobn714
    • Jan 2018
    • 31
    Re: MX-M753N POD_N1 Revisited
    your problem is in the drop down path over tray 1 the path comes together with another path sorry I am a new tech so I don't know the lingo.I had the same problem. l will look for the part # give me min. This will fix your issue
    Sent from my SM-G930V using Tapatalk
    • JoeK
      • May 2017
      • 21
      Check sensors. If its stopping at the fuser and the paper isn't visibly damaged then that would mean that a sensor is telling everything to stop. If its one certain tray then look into the sensors in that feed unit. If not then look into the registration sensor. Could be something as simple as the sensor is dirty since I've learned that a single spec of dust is the wrong place can shut everything down.
      • daileyrobn714
        • Jan 2018
        • 31
        Dunt-7302dszz Interface pass unit. This is the part that drops down on top of tray 1 when you pull out the tandem tray unit.
        • daileyrobn714
          • Jan 2018
          • 31
          Cfrm-1117ds53 transport unit. This is what I replace on the machine haven't had a problem since ran over thousands of copies
          • Hansen88
            • 1056
            If it does it every time you can in the sim mode turn off the jam sensors and see if it passes paper then. Then you will know if it is a sensor or mechanical problem. I believe it is in the aging sim where you turn off the sensors.
            • xring1958
              • 166
              It is not every time but never with Letter R or legal which makes me think it is not a paper path sensor. But it doesn't hurt to check. Thanks
              • xring1958
                • 166
                I am a bit confused. In two separate posts you mentioned two different part numbers . Did you replace both? Which one did the trick?
                • daileyrobn714
                  • Jan 2018
                  • 31
                  I do apologize if Iam making it confusing, I'm not sure exactly what the actual fix was... I replace both parts. sorry I am a new tech with little experience. [emoji848]
                  • copiertec
                    • Jan 2016
                    • 2192
                    TT-121313_ MX-M753 POD1 & 2 Jams.pdf
                    I would start here in the fuser drive section.
                    • daileyrobn714
                      • Jan 2018
                      • 31
                      I do apologize. that's what I am saying, I am not sure which one it was .I had the same problem pod-1 ... I changed EVERYTHING the helpful techs were suggesting fuser/fuser drive ect. nothing worked.so I ordered those parts for a shot in the dark. low and behold it worked. I did notice skew ing of the paper itself, feeding from tray 2 after it jammed.
                      • daileyrobn714
                        • Jan 2018
                        • 31
                        There was a dent in my paper as well..found a issue with that mylar, that why I replaced it.
                        • dwarf
                          • Oct 2012
                          • 168
                          indeed...the one-way gear in the fuser drive unit is the cause of the problem...unless the unit you installed was fresh out of the box...
                          • xring1958
                            • 166
                            It was a brand new unit.
                            • copiertec
                              • Jan 2016
                              • 2192
                              If it was an updated unit, I'm not sure. Have you tried a registration adjustment for lead edge? How many clicks are on the unit?
