Copy original message?
  • Jack79
    • Jul 2014
    • 312
    Sharp MX-3110n
    Sorry for a silly question but I cannot find out how to disable the following message after copying any page.
    1 pages of original have been scanned.
    Copy 1 pages of originals.
    Execute the jobs?
    Where can I disable this message which appear after making a copy?
  • bilyahn
    • Dec 2006
    • 1470
    Re: Copy original message?
    It will be in your system setting under copy default settings. The preview copy box is checked causing you to get this message. Easiest to go to the web interface to do this as I always seem to have a hard time finding the correct location from the panel. Sorry I couldn't be more specific but every generation they change things just enough so that you have to learn where everything is again. LOL
    Good luck.
    Bil
    • Jack79
      • Jul 2014
      • 312
      Good luck.
      Bil
      Thank you billyahn. Unfortunately I checked all copy settings and still cannot find this.
      Preview option is available before touching B?W or Colour copy button. After this machine starts copy original and displays message so touching execute is required to start printing copied document. I am really lost and do not know where can disable this message.
      • danceswrabbit
        • Dec 2013
        • 65
        under system settings then common settings then condition settings then down at the bottom initial original count settings , ran into this with scanning, this is from my notes.
        • MattL
          • Apr 2012
          • 97
          Sounds like original count, simple way to see if its on, when copying go to others at the bottom of the screen and see if this is ticked.
