Sharp AR-M620u Dark Screen
  • Taggerung08
    • Sep 2014
    • 60
    [Dead] Sharp AR-M620u Dark Screen
    I have a Sharp with a darkened screen when booted up. I can barely see the sharp logo for the loading screen and it stays stuck on that permanently. I hear the machine doing some warm-up function but not the full warm-up cycle. Any ideas?
  • JLSam
    • Jun 2015
    • 605
    Re: Sharp AR-M620u Dark Screen
    Start with an emergency firmware update. Make sure you use the right firmware if it has DSK.
    Also, Do you hear the fans turn on, and does the fuser get hot?
    Sent from my ONEPLUS A5000 using Tapatalk
    • Taggerung08
      • Sep 2014
      • 60
      I believe the only fan that turns on is the HDD fan, no fuser warm-up or other fans.
      • copiertec
        • Jan 2016
        • 2188
        You could try a HDD swap, as well. If memory serves me correctly, as it's been several years ago... I believe I had a similar issue and it turned out to be the MFP board; but, I would start with the simple and least expensive things, first.
        • Taggerung08
          • Sep 2014
          • 60
          If I disconnect the MFP board, would the machine be able to boot up for testing purposes?
          • copiertec
            • Jan 2016
            • 2188
            No, it is an integral board.
            • Taggerung08
              • Sep 2014
              • 60
              It was the NIC board, removed it and the copier boots normally.
              Thanks everyone.
              • ntbann
                • Jan 2012
                • 626
                U's didn't have a NIC card.
