Ar-5520
  • Service@PRT
    • Oct 2016
    • 181
    Ar-5520
    Got a call from an old client which the machine is getting paper jam. So i went there and see whats really causing the paper jam. And it was the paper clutch... Its broken. As i know which model it is i brought some parts with me and i got new clutch and a used one but still working good. I installed the new one and its work good. With this i only tested white copy. So i thought everything is ok. I tried copy with our invoice to check the copy quality and its cut as with the attached picture.. i tried with the used one also.. its the same.. even with the print it is half!!! .. i checked the lead void at sm 50-01 /its 50 by the default.. i played it with but to no avail still same result..
    Can anyone enlighten me with this trouble.
    Thank you
    Sent from my HUAWEI VNS-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • Jhonjon
    • Sep 2013
    • 208
    Re: Ar-5520
    Did you try the bypass if the copy is the same? If it is the same the next one is the PS clutch or try the MFP board.
    • Service@PRT
      • Oct 2016
      • 181
      Re: Ar-5520
      Yeah tried.. its the ps clutch.
        • 23010
        Re: Ar-5520
        When you install the clutch there will be a notch to keep the clutch coil from rotating when the clutch is engaged. If you were to install the clutch without the notch engaged, the clutch housing will rotate 1/4 turn before the registration roller starts to rotate also. As a result the paper arrives late to the drum. If it's left this way for a while the tugging at the wires will break one of the wires to the clutch, then you'll get another opportunity to replace that clutch. So is the notch properly aligned?
        Another reason you might see this effect is if the electromagnetic clutch has been oiled. Please don't tell me that you oiled the clutch.
        It is a common misconception that electromagnetic clutches use friction to spin up the drive. Those same individuals are known to sand the surface of the clutch plates to increase the friction. As per the name, electromagnetic clutches use magnetism. You'll get the strongest magnetic effect when you have the most contact area. So what does sanding do? It reduces the contact area. Less of the clutch plates make contact, so there is less magnetic attraction. So don't sand your clutch. It only makes it worse.
          Re: Ar-5520
          damn did you ever work in the Raleigh area? I ran across TOO many oiled clutches and torque limiters in the field! I guess you found the OTHER half!
            • 23010
            Re: Ar-5520
            Years back we had a tech that him oil fixed everything: electromagnetic clutches, leather friction pads sprockets, chains, timing belts, wire ropes ... everything.
              Re: Ar-5520
              • dsmith46
                • Oct 2016
                • 81
                Re: Ar-5520
                I guess I never thought that sanding would be bad for the clutch. I have in the past lightly sanded to get rid of stuck on particles. What would you recommend to use to clean? I use alcohol as well. I try this before replacing the clutch, to limp it through, as sometimes our parts are a pain to get in on time.
                  • 23010
                  Re: Ar-5520
                  I use alcohol to clean clutches, but usually by the time you have symptoms it's only a short term solution. We still have some models out there that the clutches cannot be disassembled. Alcohol works well to penetrate and free up sticky parts, and evaporates away cleanly. =^..^=
