Sharp AL-1045
  • delacelle
    • Nov 2008
    • 7
    Sharp AL-1045
    Hello,
    On SHARP AL-1045, I have an error "P" and the display light is red.
    I read the service manuel but nothing about the "P" error.
    Thank you for your help
    See the sky !
  • gordie
    • May 2008
    • 83
    Hi
    Is p not for paper?
    I think you will find it is out of paper or it is not picking the paper from the tray
    Gordie
    sigpic
      • 22996
      gordie has got it. The self diagnostics are not very elaborate on these machines. It means that paper did not reach the paper stop sensor (registration sensor) within so many milliseconds. That could be out of paper, or a paper jam. Have you tried fresh (unopened) ream of paper, or cleaning feed tires? Is the paper end stop set correctly so that the paper is fitted all the way to the right of the paper cassette?
      I wish all posts read like this one: "I read the manual, and have this question.....". It shows that you took a little initiative and tried to figure it out. I like that. =^..^=
      • delacelle
        • Nov 2008
        • 7
        Thank you both. Blackcat4866, i hope it is just a paper end stop uncorectly setting or a missfeed issue because i don't know where buying sharp feed roller.
        I'll see the copier tomorrow, i 'll give you a feet back on return.
        As the irish says in cork after few pints ( i used to leave there few years ago)
        Thanks a million
        See the sky !
