problem with sharp mx-m3014n
  • alamoudi
    • Jan 2019
    • 16
    Dear gentlemen
    I have a problem with sharp mx-m314n
    When printing or copy
    Please help me to resolve the issue
    Please see attachment
  • daileyrobn714
    • Jan 2018
    • 31
    Re: problem with sharp mx-m3014n
    Originally posted by alamoudi
    Dear gentlemen
    First I would check my developer unit, make sure the mag roller is completely covered and developer.
    Sent from my SM-G930V using Tapatalk
      ok so.....
      life on consumables?
      total on machine?
      what have you done?
      i always start with CLEANING the machine completely
      have you recorded any errors?
      • copiertec
        • Jan 2016
        • 2192
        I'm with Phil B on this one. What are your counts on drum, developer, transfer roller, etc.. What is the total count on the MFP, also what have you done to correct the issue? basic cleaning.... wait, don't tell me, I know, canned air! (sarcasm) That fixes everything... especially, when you blow all the crap out of the paper path on to a high voltage board. Just a guess on my part
        • alamoudi
          • Jan 2019
          • 16
          Dear Sir thank you for your cooperation with me
          In fact, I was replaced developer " MX-312NV " With a new powder " MX-312NV " I bought it before twenty months ago , Because I thought the problem was because developer . But after I've replaced it, the problem is still going on , So I'm sure the problem is not in developer , Unless there is an expiration date for the powder of developer .
          Is there an expiry date for developer ?
          • alamoudi
            • Jan 2019
            • 16
            ok so.....
            total on machine?
            what have you done?
            1- life on consumables?
            I I bought the machine in 2016
            2- total on machine?
            How can I know, Can you tell me the way to know please
            3- what have you done?
            I've cleaned the entire machine with an air blower,
            and I've replaced ink " MX-312FT " , I also replaced developer " MX-312NV "
            his message comes : Toner Replenishment in Progress
            Then comes this error : call for service code :F2-64
            • daileyrobn714
              • Jan 2018
              • 31
              They do have a shelf life, but I've never seen them expire. I'm not experienced enough to troubleshoot, I actually need to be in front of the machine. But I am curious to what the issue actually is so if you don't mind when you do find the solution can you post it thank you
                read on your fears come to light
                  I I bought the machine in 2016 ** NO HOW MANY PAGES ARE ON THE MACHINE?
                  How can I know, Can you tell me the way to know please **YOU SHOULDN'T BE WORKING ON IT THEN
                  and I've replaced ink " MX-312FT " , I also replaced developer " MX-312NV " ** REPLACED TONER/DEV DID YOU INIT BOTH OF THEM? lomfl YUP CANNED AIR... WHY DO YOU THINK WE TECHS HAVE VACUUMS?
                  SEE MY COMMENTS IN BOLD ABOVE^^^
                  now before you screw da pooch... HIRE A REAL TECH!
                  • alamoudi
                    • Jan 2019
                    • 16
                    I will
                    Thanks again for your cooperation with me
                    • alamoudi
                      • Jan 2019
                      • 16
                      In fact I am a novice in machinery maintenance
                      I do not have the money to bring a technician with a great experience
                      So I'll try to learn to fix this problem myself by reading in different sites and showing the problem to all the people who help beginners and sure I will find them
                      thank you again
                        thank you again
                        then may I suggest.. go to the " Manual Request " forum... get the Service Manual.. you SHOULD be able to google the User/Admin/Network manuals for free.
                        Study the theory and look up your issue.. most times they are simple ( could be costly ) Fixes.
                        • alamoudi
                          • Jan 2019
                          • 16
                          I will do
                          • alamoudi
                            • Jan 2019
                            • 16
                            The cause of the problem is :
                            HIGH VOLTAGE POWER SUPPLY BOARD PCPH0548 MPH3333 " RDENU0058QSPZ "
                            • lky1978
                              • Mar 2009
                              • 483
                              replace drum charger kit MX-311NC first before order the HV board. Sound like main charger leaking.
