ARM277 Fusing Unit compatible with AR271FU?
  • jomaridel319
    • Jan 2019
    • 7
    [Misc] ARM277 Fusing Unit compatible with AR271FU?
    Hi, I got confussed when I bought a fusing unit AR271FU, it stated that it compatible with AR-M277 machine, but when I open the box, the fusing unit inside is totally different from the ARM277 fusing unit, did someone already tried to use this AR271FU to ARM277 machine? Thanks
  • harleyrider
    • Oct 2011
    • 348
    Re: ARM277 Fusing Unit compatible with AR271FU?
    In the USA we use AR272FU for that model.
    • jomaridel319
      • Jan 2019
      • 7
      My machine arm277 also came from USA and the ebay seller still insist that this is compatible heater unit for ARM277, but its totally different.
      AR271FU-GENUINE SHARP ARM208 FUSING UNIT 120V, OEM | eBay
      • jomaridel319
        • Jan 2019
        • 7
        Is there anyone tried to use this fusing unit AR271FU to ARM277 unit? Thanks
          • 22954
          As far as I can tell, you should be able to use AR270FU, AR271FU, or AR272FU in your model AR-M277.
          • jomaridel319
            • Jan 2019
            • 7
            OK will try to install and will see if it will fit. Thanks for your reply.
            @harleyrider - Thanks for your reply
