Dead MX-6240N
  • teklife256
    • Sep 2012
    • 164
    Dead MX-6240N
    One moment I was printing the 22-6 and then exiting sim mode the mfp locked up. After hard cycling power the screen is black and the green main power LED on the display panel just flashes. The LED never goes solid and pushing the sub power switch does nothing. At this point I'm open to any helpful ideas. Is there somewhere in the manual or on IDNC that tells what the LEDs on the PWBs mean? I have a solid red LED and a flashing green LED on the PCU PWB. On the MFPC I have a flashing red LED and two solid green LEDs. I imagine the state of the LEDs has to mean something. Scouring the manuals I missed any mention of the LED meaning.
    Thanks for the help
  • bilyahn
    • Dec 2006
    • 1467
    Re: Dead MX-6240N
    If your fans are running then it is the SD card, very common problem through all Sharps.
    Good luck.
    Bil
    • lopakad1
      • Nov 2014
      • 69
      Re: Dead MX-6240N
      I've had the same problem before try unplugging the hard drive. It's a long shot but it's work for me once or twice.
      • teklife256
        • Sep 2012
        • 164
        Re: Dead MX-6240N
        Solution turned out to be replacing the SD card. Thanks all for the help.
        • Dewald
          • Feb 2015
          • 15
          Re: Dead MX-6240N
          Hi does anyone have a copy of a image for the sd card for me? I would much appreciate it
