Sharp MX3640 forever Sharp Logo on power up
  • buzz
    • Aug 2013
    • 288
    Forever sharp Logo on power up
    cant clear.
    Refit SD, Compact flash, and ROM dimm. Still stuck on LOGO.
    Thinking SD, any tips on this?
    Re: Sharp MX3640 forever Sharp Logo on power up
    Originally posted by buzz
    Forever sharp Logo on power up cant clear. Refit SD, Compact flash, and ROM dimm. Still stuck on LOGO. Thinking SD, any tips on this?
    reload firmware for starts
    • EasyRider
      • Jan 2015
      • 86
      After what he said, try replacing SD card. (you said refit, not replace)
      This link shows how. http://www.copytechnet.com/forums/sh...ht=#post722712
      Link is on a monochrome but the same applies for the MX3640, in this case.
      Good luck!
      • repn1999
        • May 2010
        • 310
        I would replace the hard drive and then do and complete restore from dead machine process. I usually make a new sd card for it and then put in a new hard drive when i get this and that ensures the problem doesnt return. Sharp changed the hard drive on these several times, and if you have one of the early toshiba or hgst ones they are crap. I use wd blue 500gb 2.5 laptop drives without an issue.
        • buzz
          • Aug 2013
          • 288
          Thank you all. It was a bad SD card.
