Sharp MX 4111 Customer can't copy a check in color
  • Doug James
    • Jan 2012
    • 935
    [Misc] Sharp MX 4111 Customer can't copy a check in color
    This customer says they try to copy a check that someone has wrote them and it says "check original" they then hit OK. The copier will spit out a blank page. Then says erasing data. Thinking that this is some anti counterfeit feature. Not sure what to tell the customer. Any help will be very appreciated. Thanks !!
    Re: Sharp MX 4111 Customer can't copy a check in color
    correct anti-counterfit
    did they try scanning in B&W mode only?
    • Doug James
      • Jan 2012
      • 935
      Yep, it worked then... Thanks so much for your help... Really appreciate it !!!
        be nice if i got a thanks
        • ntbann
          • Jan 2012
          • 626
          Here you go.
          • Doug James
            • Jan 2012
            • 935
            [QUOTE=Phil B.;728565]be nice if i got a thanks[/QUOTE sorry about that !!!
