mxm365
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    mxm365
    heres a strange one
    customer prints this order form
    column A has numbers . B has description C has prices D is some lines about 3 inches long to write stuff in
    these line will continue across the page where they shouldnt be
    pls note
    Sharp toner sharp supplies .
    Tried rebuilt fuser. swapped fuser. pm on drum with main charge kit MX560mk. new transfer roller kit. Fresh Dv. latest firmware
    checked blanking lamp.
    but heres the odd part. only seems to happen on first page.
    gonna try laser as we have a used one here.
    I fix copiers ...Well Sorta
  • mansart
    • 852
    Re: mxm365
    is there a problem on other printed documents?
    • Hansen88
      • 1068
      Re: mxm365
      Are the fuser pressure levers in the down position? Also in system settings go to device control and change setting of fuser temp from 16 to 23 to 23 to 28lbs.May help.
      • fireater
        • Apr 2006
        • 253
        Re: mxm365
        yup
        even on list prints
        • fireater
          • Apr 2006
          • 253
          Re: mxm365
          yes and even replaced entire fuser with another rebuilt one
          yes device control is set to the thicker paper.
          we replaced the lsu. not fixed.
          put new dev in it and it works for now . yes it has a newer dv unit . part number ends in 15. there is a newer part ending in 16 but none of our other units are doing this
          • fireater
            • Apr 2006
            • 253
            Re: mxm365
            its definitely the fuser. not sure why its happening .. have some ideas about settings in 43-2 might increase warm up time and fuser rotation time. perhaps lower roller is not warming up fast enough
            • repn1999
              • May 2010
              • 310
              Re: mxm365
              could be an issue with the build up on the web from running the fuser in 23 plus mode on plain paper. doing this is a double edged sword. i would reset the machine soft switches just to make sure temps have not been messed with. change mfp destination in sim 26 to something besides us...then restart, then put it back to us and restart again. the web kits were changed early in production to a web with more oil due to strange issues like this. make sure you use sharp webs and not aftermarkets.
