ARM-450N copy/print quality
  • DINGO
    • 661
    Hello
    Y have a quality probem in one arm-450n.
    the problem is, the copy and the print is more dark in rear that the top.
    y just try change: unit drum, developer drum, and transfer and main charge (corona)
    and the print and copy have a litle diference betwen the top and the rear.
    the copier have only150.000copies.
    have someone any idea that can help me.
    thanks in advance
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    Dingo, depending on what your copies look like, it's more than likely the developer unit. After cleaning the developer out, check the mag roller. If it's dark on one end, sometimes cleaning with a scotch brite will work, but we typically replace it. The other thing to check is the gear on the transfer roller. If it wears, it will give you light copies on the rear frame side. We generally replace these at every supply change.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • xeroxsharp
      • Nov 2008
      • 270
      Hello DINGO. I think if you replace the developer unit the copy-print will be OK. Check SIM 80-2(128) before SIM 25-2. Good luck.
      • DINGO
        • 661
        re
        hanks,
        but, y have just try whith another developer unit, of another copier that is good, an the problem is the same.
        But there are one thing strange, i put sm 80-2 is in (80), and the copy is not with good darK?
        Y think that is a problem of transfer or charge, but where??
        y jus change the transfer and main charge, the dv unit, an the opc(drum) unit??
        thanks, one time more
        • DINGO
          • 661
          re
          when y say top rear, is for exemple in paper A4 mode,(not A4R) is more dark in top and comes lightly gradualy to rear.
          y hope that understand, by.
          • xeroxsharp
            • Nov 2008
            • 270
            Try to replace transfer roller assy not only transfer roller from 100k kit. I had same problem when I replaced only transfer roller and got pure copy-print,than I replaced transfer roller assy and it was ok.
            • DINGO
              • 661
              • xeroxsharp
                • Nov 2008
                • 270
                I did not found nothing about tandem copying in SM. About your main problem-try to clean mirrors in lasser unit,because the mirrors could be dirty,or replace the lasser unit with new if you have it,that will take less time. I think that is all or something is wrong with rails or side door assy. Good luck to you.
                • lobbelios
                  • Oct 2008
                  • 5
                  Hello! Have you checked the springs behind the transfer unit. On a few of my machines one of the springs thats attached to the wite "nobs" behind the unit was loose and did not give the right pressure.
                  • DINGO
                    • 661
                    re
                    Ok
                    Y have one more time: take out, drum unit, dv unit, transfer unit, clean anything, , and chek the contacts of the transfer unit and give him a litle pressure, and well, the copy stay aceptable.
                    But My confuse is the dark of the copy is not normaLy, because y do the sm 25.2, and its stop at (96), y force them whith the 80-2 to (80). the copy is aceptable but not normaly for this copiers, y have anothers, and this problem starts of one day in the morning.
                    well, y hope when change the dv and the drum every stay normaly.
                    ah, this copier give two or four times F2-39?? means somthing??
                    by, and sorry my english.
                    • ZOOTECH
                      Senior member of CRS
                      • 3375
                      F2-39 says there is trouble with the process thermister. Check connections and PCU pwb.
                      • mrfixit
                        Senior Technician
                        • Sep 2007
                        • 83
                        If the laser unit has ever been replaced (which is common on these models) the height adjustment may cause it to be lighter on one side or someone may have adjusted the laser height to compensate for the scewing this machine always developes.
