MX-2651, MX-3071 etc
  • xordi69
    • Jun 2010
    • 200
    Good morning.
    I want to accomodate this model printers in two LAN networks at the same time, by wifi and wired.
    Whith the MX-2651 I need MXEB18, ok, but in Sharp says that the accomodation of two lans it's an option, but I d'ont know how to do it.
    I have tried whith this model and it don't work. Someone have do it, any manual please?
    Excuse my very bad english.
    Thanks.
  • spanky
    • Sep 2012
    • 468
    Re: MX-2651, MX-3071 etc
    I believe you can have wired or wireless, but not both.
      most brands don't offer wired/wireless networking in the same machine.. at the same time
      others offer an OPTIONAL wireless card... but have heard they aren't always reliable
      • davod.mardani
        • Feb 2015
        • 32
        Originally posted by xordi69
        Good morning.
        Thanks.
        I'm sorry!
        I do not know about sharp copiers. But i'm ready for TOSHIBA!!
        Sent from my Mi A1 using Tapatalk
        • Ben Around
          • Apr 2012
          • 151
          +1 Spanky nailed it first
            • 23006
            You can do two wired networks, but not wired and wireless simultaneously, especially with manufacturer network cards. =^..^=
            • mansart
              • 852
              The newer Sharps will create their own wireless network. So for example you can hardwire to a customers network as normal. But also the Sharp will publish its own independant wireless network that can be joined and then connect to printer. This is mostly aimed at Guest cell phone printing.
              This wireless network the Sharp creates does not have internet access
              • boutn
                • Jun 2016
                • 547
                MX-3071 series should be able to enable wifi AND wired at the same time...there is an option to keep it on if i remember correctly.
                Also, 2 wired connections is possible via USB-to-ethernet adapter. This has to be enabled in the Simulations though. (SIM 26-33)
                2nd connetion only supports printing. (no gateway/smtp/...settings available)
                We tested some usb-to-ethernet adapters, and only the TP-link seems to work...
                • xordi69
                  • Jun 2010
                  • 200
                  Thanks boutn
                  But one question.
                  in MX-3071 how to enable wifi and wirwe at the same time?
                  And what i enable in 26-33?
                  Thanks!!!!!
                  • mansart
                    • 852
                    Under system settings....Network Settings....Use this setting to switch between [Wired Only], [Wired+Wireless (Access Point Mode)] or [Wireless (Infrastructure Mode)]
                    As I understand it .....
                    Wired Only.....is the traditional method, joins machine to customer network via wire, machine has one ip address
                    Wireless (Infrastructure Mode)....same as above but machine is joined to customer network via wireless
                    Wired+Wireless (Access Point Mode).....two ip addresses, machine is connected to customer netowork via wire, while at same time the Sharp will publish its own wireless network in order to enable Guest printing, this wireless is not intented to join another network. It is simply an "Access Point" to the machine to enable guest printing.
                    • xordi69
                      • Jun 2010
                      • 200
                      Yes mansart, but in this models,using an external adapter, usb to lan, you can have a second lan,I'll hope, but only for print, as it says boutn.
                      I will try it this week and tell you if it works.
                      • bilyahn
                        • Dec 2006
                        • 1470
                        This is from the MX2640n series but I do not think it has changed. This is from Tech bulletin MFP-TB-689, TB also gives instructions on how to set up each mode
                        2.1. Modes in Wireless LAN
                        Two connection methods are available for the wireless LAN
                        Infrastructure mode and Access Point mode.
                        Infrastructure mode, two client devices communicate with each other via an access point. In Access Point mode, two
                        client devices communicate with each other directly without using an access point
                        Mobile devices and MFP
                        communicate with each other directly to print and scan from the MFP.
                        Infrastructure Mode
                        This mode allows for wireless communication between two client devices via a host (access point). A MFP
                        connects to an access point to obtain an IP address.
                        Simultaneous usage of Infrastructure mode and wired connection is prohibited.
                        Access Point Mode
                        MFP connects to other wireless devices without preparation of other access point while the MFP itself functions as
                        the access point. To be more specific, it works by other wireless devices acquiring the IP address from MFP.
                        Print/Scan features in MFP will be available from the mobile devices which have no access to intranet.
                        Simultaneous usage of Access Point mode and wired connection is allowed. However, mobile device will not
                        be able to connect to the intranet/internet which MFP is currently connecting.
                        Good luck.
                        Bil
                        CCE1111-MFP-TB-689 wireless setup.pdf
                        • boutn
                          • Jun 2016
                          • 547
                          Infrastructure Mode
                          Access Point Mode
                          Good luck.
                          Bil
                          [ATTACH]42162[/ATTACH]
                          As i was saying...this is the first model that can activate both at the same time.
                          Wired lan + wifi infrastructure
                          Or 2 times wired lan
                          things do change
                          • Mattesthlm
                            • Apr 2022
                            • 10
                            Yeah you need Connection Type: Wired+Wireless (Access Point Mode) in network settings and SP mode 26-50 Wireless Set 1, then it should work, or other way around and it changes automatic to wired+wireless in network settings
