MX-C300w keeps rebooting when network cable is plugged in
  • Hansen88
    • 1079
    Like the title says when the network cable is plugged in the machine will endless keep rebooting. If I unplug the network cable it will boot up. I was thinking replacing the PCU PWB but that is just a guess. I am hoping maybe someone else has seen this problem before.The only things I have done so far is reseat board connections.Thanks for any suggestions.
  • danceswrabbit
    • Dec 2013
    • 65
    Re: MX-C300w keeps rebooting when network cable is plugged in
    The times i've seen this in the copiers it has allways been a print job. Something that confuses it. gotta delete the offending print job from the computers print que.
      before that I would try:
      new Network Patch cable
      put a power monitor on AC line
      put a network surge on the unit .. plug in net cable .. reboot
      do they have an IT dept?
      have them monitor the issues on that IP addy?
      could it be to duplicate IP problem?
      IMHO
      other than possible bad NIC.. the machine functions properly.. RIGHT?
      I always look at other possible causes before jumping to $$$$$ parts! ( your customer/manager will be happier also!
      • daileyrobn714
        • Jan 2018
        • 31
        yuuuup
        Sent from my SM-G930V using Tapatalk
          my bad... I ASSumed that "Printing 101" class had been covered. Yes this should be checked.. but the IT Dept (hopefully) would notice that.
          • spanky
            • Sep 2012
            • 468
            hook up a laptop directly to the printer with a patch cable and try printing from the laptop.
            This will tell you if the problem is in the copier.
            • guitar9199
              • Sep 2016
              • 1100
              Check for "Power over Ethernet". This does all sorts of bad things to copiers.
              • ntbann
                • Jan 2012
                • 631
                IT must be really good in NC. Here in Mich. customers IT are usually dumber than a box of F***ing rocks!
                • RobertOB
                  • Dec 2018
                  • 26
                  Please See Bulletin # REP2072F
                  It mentions that the most recent firmware has a "Correction of the trouble that MFP reboots when receiving the specific SNMP packet."
                  Do the Firmware!!
                  • Hansen88
                    • 1079
                    Thanks for the suggestions. I was going to do the firmware but it would not stay up long enough before it would reboot again. When I went back and was just checking things it started working. I didnt change or do anything yet so nothing was different. I should have done the firmware then,but at that point didnt think about it. For now its good. If they have more problems you guys have given me ideas. Cust is a small towing company so no IT. I will admit I am old school hands on mechanical and IT is a weak spot beyond the basics.
                    • dsmith46
                      • Oct 2016
                      • 81
                      This made me chuckle a bit. Yes, the IT Dept "should" be able to find a bad print job, but in my experience, most of the IT guys I deal with aren't too bright. Haha!
                      • Leebs14
                        • Feb 2014
                        • 457
                        Hi there, I had a similar problem with one of these machines where it wouldnt reboot but it would just lock up, no buttons worked on the ops panel or anything once the network cable was plugged in. In the end we changed the IP address to something different and it worked fine, we then put it back to the original IP and it locked up again - Weird. So we simply changed the IP address and reset the pc's to print to the new address and it has been working fine ever since.
                        • kingarthur
                          • 1383
                          Had this on a KM device, went round and checked all print queues until i found one with stuck jobs, cleared the queue and it was fine, discovered that KM print drivers hadn't been installed on her PC, so every time she printed a certain PDF document, the copier would reboot, got her to send job to her colleague with correct KM drivers, and it printed, installed correct drivers and have had no more problems....
                          • dogg_man
                            • Jun 2011
                            • 48
                            Things that can cause this issue.
                            NIC speed
                            Print jobs
                            POE
                            IP conflicts
                            Bad Network cable
                            Bad Network port on customers switch
                            Printing via outdated driver or incorrect driver
                            Always have services you don't need on the copier disabled (pop3, DDNS etc) and always make sure you have the latest firm installed.
                            • ICEuk
                              • Oct 2017
                              • 9
                              Remove any smtp settings.
