Sharp mxm365n
  • TSS
    • Jul 2018
    • 29
    Sharp mxm365n
    I am new to sharp.Has anyone had issues with mxm365n jamming at exit sensor in adf unit. Getting to exit sensor looks tough to get to.Some copies go through,but eventually jams misfeed.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Sharp mxm365n
    Yes, if the jam light is on with no paper the flag gets a little gummy and sticks. The ends of the actuator need to be cleaned and tiny drop of oil helps.
    Remove front and rear covers, remove paper tray with 4 screws to access.
    • bilyahn
      • Dec 2006
      • 1470
      Re: Sharp mxm365n
      I also trim the plastic frame piece that the sensor flag rides against. You can't miss it once you have the unit apart but you will need to remove the lift tray metal bracket (2 screws) to get to it easily. I have had this put a slight drag on the flag when it goes back to the home position and you will get SPPD5_S jams. Not too hard to take apart.
      Good luck.
      Bil
      • moose55
        • Mar 2017
        • 143
        Re: Sharp mxm365n
        It depends on if you are talking DSPF or RSPF? DSPF you need to remove front and rear covers, and also top cover (cross member). Remove the cross member, and original tray, then you can access the cove that the sensor is under. If it is an RSPF you get to it through the bottom side very easily.
        The Moose is loose!!
        • TSS
          • Jul 2018
          • 29
          Re: Sharp mxm365n
          Thank you all for your advice.Sensor just needed another wrap.Exit sensor was not coming back quick enough.
