Spf copy have a straight line (black marked) only in spf option.
  • jesus najera
    • Jul 2025
    [Misc] Spf copy have a straight line (black marked) only in spf option.
  • copiertec
    • Jan 2016
    • 2205
    Re: Spf copy have a straight line (black marked) only in spf option.
    Did you clean the mirrors in the optical section?
    • EasyRider
      • Jan 2015
      • 87
      Hey Jesus,
      Does that line go all the way edge to edge of the paper? Hard to tell on this pc.
      If it does, that means (usually) that the line is from the main charge, cleaning blade/drum, or even the process unit seal. Usually.
      I said usually, mmmk!
      Look at those and good luck!
      • Reject Devil
        • Nov 2016
        • 5
        Check the slit glass, the small strip of glass. Look at it from an angle and you might see a pen mark, white out or something on there causing the line.
        • jesus najera
          Yes, It is clean.
          • jesus najera
            thanks for the reply..
            but supose that you said is true..
            why only the copy have the straigth mark in the spf function.. in the normal OC scaner glass the copy havent the problem.
            thanks again.
            Originally posted by EasyRider
            Hey Jesus,
              • 23007
              If your line is not through the image lead and trail voids, and only occurs when using the SPF, there is dust or dirt in the optics. Frequently it can be seen easily on or through the slit glass. Less frequently a particle of dust on one of the mirrors can align just right when scanning through the slit glass only.
              My recommendation is to leave the mirrors installed, and wipe the front surfaces with your favorite glass cleaner or alcohol. Sometimes it helps to slip a piece of white paper behind the slit glass to see ink marks.
              Please do not remove the mirrors for cleaning. You will have great difficulty getting them back installed and aligned, if it can be done at all. =^..^=
              • Jack79
                • Jul 2014
                • 312
                As mentioned twice. Clean slit glass. Check both sides.
                  -=IF=- on copy ONLY (internal prints ok?)
                  HAS to be Slit Glass or other optics...
                  • jesus najera
                    [/QUOTE]
                      • 23007
