Sharp AL 1200 error code E-2
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    Anyone know what E-2 is? I don't see that code in service manual.
  • OlliK1969
    • Nov 2016
    • 311
    Re: Sharp AL 1200 error code E-2
    Code
    E2
    Description
    LAMP Paper jam lamp blinking. Paper jam (paper entry section) DETAIL 1) Paper entry detector (PIN) malfunction 2) Paper entry detector (PIN) signal recognition error
    Remedy
    Paper entry detector (PIN) signal recognition error 1) Paper entry detector (PIN) trouble 2) Paper entry detector (PIN) signal input circuit trouble REMEDY (Check) 1) Paper entry detector (PIN) 2) MCU PWB paper entry detector (PIN) signal input circuit (Remedy) 1) Paper entry detector (PIN) replacement 2) MCU PWB replacement (After work) 1) When the MCU PWB is replaced, perform simulations to input various set values and adjustment values.
