Sharp MX-4141N Phantom Paper Jam
+ More Options
Posts
  • dsmith46
    • Oct 2016
    • 81
    #16
    Re: Sharp MX-4141N Phantom Paper Jam
    I would look at replacing the pickup, feed, sep rollers in the ADF. Usually if they are worn out or slipping on the paper, they will give that jam code, since the paper is not reaching the first sensor in time. Sharp usually recommends replacing these rollers at 100k, so you aren't too far off, not too mention if they are the original rollers, then they are old.
    • hanfordzucc
      • Apr 2019
      • 5
      #17
      thanks!
      • mttech
        • Mar 2014
        • 127
        #18
        You say it never misfeeds but you get a misfeed message. Does it continue trying to feed after all of the pages have been fed? This would give you a misfeed message but it will be more involved than just replacing rollers.
        • hanfordzucc
          • Apr 2019
          • 5
          #19
          no it doesnt, there are no physical paper jams, no attempting to feed additional sheets....it just constantly is giving that error.
          • bilyahn
            • Dec 2006
            • 1470
            #20
            With that jam I would take the top assembly off where the feed rollers are and check if there is a piece of paper blocking the paper path preventing the paper from reaching the first sensor. That's the most common cause of that particular jam. If there is no paper then test the SPPD1 sensor in simulations to see if it is bad.
            Good luck
            Bil
            • Andypraeuner
              • Jun 2013
              • 33
              #21
              Check the sensor actuator in case someone in the office had a jam and pulled the paper back out and dislodged the SPPD1 actuator.
              • driving lots of miles
                • Jun 2016
                • 397
                #22
                Good luck
                Bil
                I would agree with either of these two previous posters
                • Reject Devil
                  • Nov 2016
                  • 5
                  #23
                  I would start with checking your paper feed tray rollers. It sounds like they are wore out and not pulling the paper out of the tray.
                  • JeffG
                    #24
                    If you have tried cleaning it out already you could try runniing sim2-3 and activate all motors then run a stack of pages through. This helped me clear a mystery jam one time, forcing the pages through ended up dislodging a small piece of paper that i was not able to locate.
                    • copierdude1114
                      • Dec 2015
                      • 29
                      #25
                      Take off the lid that has the 1 screw, most likely something jammed up in there with the feed rollers. These doc feeders are really easy to disassemble once you get the front and back covers off! I believe it's 4 screws after covers are off and you can get at the whole feed assembly.
                      • repn1999
                        • May 2010
                        • 310
                        #26
                        I would actually check the sensors with a meter. Supply voltage is 5V on them all. the service manual will tell you which sensors read what on the signal line, I have had to replace just about all the sensors in those particular doc feeders at 1 time or another. I also have had a couple with voltage supply to the sensor issues and had to replace the dspf control pwb to remedy that. Sharp actually put out a bulletin about bad sensors in general and this feeder does contain some of the types of sensors in that bulletin. Rather than guess at what it is. check your voltages. Look in the book at the signal list and check to see which sensor isn't reading correctly and change that one.
