Error pictures of a Z52 Sharp copier
  • Sven76225
    • May 2019
    • 2
    [Dead] Error pictures of a Z52 Sharp copier
    Hello copytechnet members,
    I have a broken Sharp Z52 copier on my work-bench. I need help with the repair. I am radio TV technician, unfortunately I have no repair experience with a copier. Maybe I need the service manual.
    I get an inverted copy of the previous copy. Only this previous copy is inverted. Black on the original is white and what was white is black now.
    Error pictures of the defective copier :
    When a blank sheet of white paper is copied, you get that copy.
    For this presentation :
    That's the copy result.
    I'd be happy for help. Thank you.
    Best regards,
    Sven
  • Hansoon
    • Sep 2007
    • 3381
    • 1stcavvet
      • Apr 2015
      • 231
      Re: Error pictures of a Z52 Sharp copier
      replace the drum unit and the toner cartridge----if you can find any GOOD LUCK
      • Sven76225
        • May 2019
        • 2
