MX-M264N SD card issue
  • kirkeb
    • Dec 2012
    • 31
    Have a 264 being used as copier and printer. No fax or scanning. No HDD. SD card is going bad. Replacing it with new one ordered from Sharp tomorrow. Been reading the various threads on this subject. Guess we've been lucky as this is the first one we've had to replace. From reading service manual power down machine, remove old card, install new one, power up and flash firmware with latest version. Is this correct procedure? Anything else i need to do? thanks in advance.
  • OlliK1969
    • Nov 2016
    • 311
    • dsmith46
      • Oct 2016
      • 81
      Re: MX-M264N SD card issue
      I would also do a complete backup of address book, and device cloning before replacing. This stuff is stored on the SD card if no HDD is installed.
      • ntbann
        • Jan 2012
        • 632
        After installing the sd card and updating firmware I would also take it out and make a copy of it with rawcopy. Then You wont have to buy the expensive one from Sharp.
        • nazmi_exa
          • Nov 2009
          • 24
          how to dupicate or make a raw copy of all sd card data inside? if just plug in at computer, its no driver to open that sd card..so how? can teach me? I have a same problem with many more sharp machines with sd card issue..
          • ntbann
            • Jan 2012
            • 632
            Download raw copy and install it on your computer. Then plug in sd card from copier and copy using raw copy.
