mx2640 f2-78
  • ash_572
    • Oct 2008
    • 523
    [Error Code] mx2640 f2-78
    I have a sharp mx2640 with an error code of f2-78. colour registration is also out.
    I have cleaned the ID sensors and replaced the transfer belt. colour density is very strong.
    following sims tried and failed.
    sim 44-02 pcs_F LED ADJ error, R LED ADJ error.
    sim 50-22 ERROR ; SENSOR CALIBRATION F 04
    I have tried using the special tool in sim but sim 44-13 does not exist.
    firmware is upto date.
    please advise
  • moose55
    • Mar 2017
    • 143
    Re: mx2640 f2-78
    Just saying this to cover myself...make sure the ID sensor is completely clean! Next I would try a different (or at least rebuild) primary transfer unit. It may ultimately be an LSU.
    The Moose is loose!!
    • copiertec
      • Jan 2016
      • 2186
      Re: mx2640 f2-78
      Agreed with moose55, try cleaning the sensor again and a different transfer belt first. Next, per service manual, replace the image density (registration) sensor, next service manual is saying to replace PCU PWB.
      • ash_572
        • Oct 2008
        • 523
        Re: mx2640 f2-78
        Hi
        i have cleaned the ID sensors and replaced the primary transfer belt and still the same. I will order some ID sensors
        • OlliK1969
          • Nov 2016
          • 309
          Re: mx2640 f2-78
          Hi
          clean ccd and please clean the color registration sensor ( incl. gray field)
          44-2
          50-22 all near 0.0
          44-6
          44-26
          restart
          46-74
          restart
          • repn1999
            • May 2010
            • 310
            Re: mx2640 f2-78
            I assume you stopped the machine and looked at the image on the belt before doing any more troubleshooting to see if the image is screwed up there. I am also assuming you have updated the firmware to v6.0 which is the current level. There was a firmware update to reduce the occurence of F2-XX codes. I have seen bad density sensors on these machines before. I have also seen a bad belt unit cause this which you already replaced. I have also seen machines that were too far out of adjustment cause this issue. When I see these errors I usually set everything in 50-20 to default and try the whole process again. if 50-22 fails I bypass it and complete 44-6 and 26 and then try 50-22 again and this usually fixes it. That being said......make sure to only clean the density sensors with alcohol and a clean white rag. check all of the drums to make sure none of them are hard to turn or make noise when you turn them. I had a tech who was getting this error and it was solely because he didnt powder the damn drums and blades very well.
            • tonasis
              • Oct 2015
              • 10
              • ash_572
                • Oct 2008
                • 523
                Re: mx2640 f2-78
                • tonasis
                  • Oct 2015
                  • 10
                  Re: mx2640 f2-78
                  • ash_572
                    • Oct 2008
                    • 523
                    Re: mx2640 f2-78
                    Could also be the transfer belt worn.
