Sharp MX-M200D jamming
  • tsbservice
    Field tech
    • 8019
    Hi Sharp experts, need help on this one. Have to admit I never till now touched Sharp machine. Normally I work on KonMin and Toshiba MFPs.
    Doing this for a client. Machine rattles in area around fuser drive and every copy made its way to fuser and jams.
    I can rotate upper fuser roller drive gear easily by hand(had no time to remove fuser though). Looks like fuser drive gear fixing pin/rib is broken or something?
    Any common faults on these? BTW counter is around 150k.
    TIA,
    tsb
  • stu
    • Feb 2019
    • 2
    Most common fault is the heat roller gear failing sometimes it's just the peg inside the gear shears allowing the gear to turn but not the heat roller,part number I think is ngerh0540fcz3 or maybe z4
    • TRJS
      • Mar 2018
      • 15
      Re: Sharp MX-M200D jamming
      If you got 150k out of fuser you're lucky. Had fuser gear break many times. Exit/turnover will get brittle and break also. Keep filters clean/remove.
      • dwarf
        • Oct 2012
        • 168
        fuser mounting screws are somehow damaged...brittle plastic...
        • tsbservice
          Field tech
          • 8019
          Indeed, it was broken heat roller gear. Old gear was brown color so fried, new gear white plastic.
          I guess they changed material at some point.
          Thanks for the input guys.
