mx-m565n Cleaning blade flip
  • Demon33
    • Jan 2019
    • 38
    I have a lot of cleaning blade flipping after doing a PM on those model & I saw a tech bulletin that say you have to put stearic acid powder on the drum when replacing it . I never did that on any sharp.
    Every other tech I speak to don't seem to have that problem & they don't apply stearic acid powder...
    Question 1 : Am I the only one getting flipping blade ?
    Question 2 : Do you guys put stearic acid powder when you change the drum?
    Thank you
  • dsmith46
    • Oct 2016
    • 81
    Re: mx-m565n Cleaning blade flip
    The company I work for has pretty much abandoned the 560mk kits. Those cleaning blades are junk. Instead, we use the 503mk kits. The charger grid and saw tooth are the same, but you have to transplant them into the frame of the 565 charger, as the frames are different between the series. I have also noticed that if the blade flips bad enough, it can cause a lot of stress on the process unit frame, possibly causing more flips in the future as it is tweaked out of shape. The process units are cheap enough that I carry one with me in the event I have a bad flip; ie...drum completely locked and wedged.
    As a side note, I don't put any extra powder on the drum or blade, other than what is already on there, along with yellow toner.
    Hope this helps!
      I never put a blade in the Drum or the ITB WITHOUT powdering it... you can use yellow toner AS LONG AS IT DOESN'T HAVE DEV POWDER IN IT.
      • JR2ALTA
        • Feb 2010
        • 2033
        This has been a very solid unit for us. Basic mechanics and zero board issues. I am not aware of any blade flipping either. The only thing that stumped us was the transport rollers above the fuser get concave causing toner build up on fuser guides. But even that is a 10 minute fix.
        • bilyahn
          • Dec 2006
          • 1470
          I'm with JR2ALta. We have quite a few of these with 1M copies and have not had this issue so far. Use the 560MK kit without any problems. Don't use any additional powder just what is on the drum to start with unless it doesn't turn smoothly by hand then I will add some additional powder when I put it back together until I can get the drum to rotate easily. Wonder what could be causing your problem.
          Good luck.
          Bil
          • mike2565
            • Aug 2018
            • 12
            Make sure the red felt seals on the sides are put on after the blade is put in. I had the same problem and since I put seals in this way the problem went away. I hope this helps.
            • dsmith46
              • Oct 2016
              • 81
              These felt pads go on BEFORE the blade is put in, just FYI. If you are putting them on TOP of the blade, you're doing it wrong.
              • mike2565
                • Aug 2018
                • 12
                If you put them on before the blade is on then one side or the other will lift the the blade and cause it to flip. If you look at it after the blade is installed there is plenty of room to get it on there, the bottom blade is then installed. I thought the same thing you did about them but since I started doing them this way I have never seen this problem again. There is another thread like this on my board and I had another tech tell me the same thing about the felt pads.
                • Demon33
                  • Jan 2019
                  • 38
                  I'm defenetly goin to test that. The idea look crazy but what the hell.
                  • repn1999
                    • May 2010
                    • 310
                    • Nachoman4life
                      • Oct 2007
                      • 212
                      Placement of the felt seals matters alot, if either are too far inside than they should be, blade flips will happen.
                      Where the heck is my spring hook?
                      • bigdaddyooo
                        • Dec 2014
                        • 211
                        Mike2565 is absolutely correct. Put the seals on AFTER you put the blade in. Just butt up the seal to the blade. I flipped a blade 3 times in same machine before doing it this way. ZERO since.
                        Are you the police? "No ma'am, were musicians"
