Customer not on a network,wants scan to folder
  • Hansen88
    • 1053
    I am a old school tech and my it-computer skills are not great. Trying and learning but have a ways to go. I have set up scan to network folder but customer has no network. Copier is just plugged directly into computer. I guess this is called scan to PC? It looks like according to sharp we would need sharpdesk scanner? I dont know. How do I set up scanning with computer just plugged in directly to MFP? Thanks
  • mansart
    • 852
    Re: Customer not on a network,wants scan to folder
    Plugged in via ethernet cable or USB?
    • JLSam
      • Jun 2015
      • 605
      So...
      I might be wrong, but I've never been able to set up scans to PC with a Sharp machine using USB cable.
      Now, I have set up scan to PC using both SMB (network folder using username and password) and FTP (Sharpdesk software) when using a crossover cable. You can make one yourself, takes 2 minutes. Just set the copier and computer in the same IP range with the copier IP as the gateway set up scan normally.
      It would be easier, depends on the model though, if you set up the copier as an access point. Then the user just logs in to the wifi of the copier. With the computer fully networked to the copier directly, you can set up scanning normally.
      Good luck[emoji3577]
      Sent from my GM1917 using Tapatalk
      • Greg Kinloch
        • Jun 2019
        • 9
        you need Sharpdesk. drawback is unless you use network scanner tool it will not directly scan to pdf only .tiff till you converted. good luck
        • ZOOTECH
          Senior member of CRS
          • 3375
          Direct scan to PC via USB is from a Twain driver (as I remember).
            • 22990
            You haven't mentioned what model. =^..^=
            • JLSam
              • Jun 2015
              • 605
              I called sharp a long time ago, I was told this can't be done with Sharp MFP's via USB and the TWAIN driver. Sharp rep said it needs to be in the network for TWAIN to work.
                • 22990
                I seem to recall this too. =^..^=
                • JR2ALTA
                  • Feb 2010
                  • 2030
                  The reason Mansart asked is because you can throw away your USB cable and connect via ethernet. Then you can set both to a static address and print and scan all you want.
                  • bilyahn
                    • Dec 2006
                    • 1470
                    There is an old GDI version of Sharpdesk that you can use to scan over USB. It is a pain to setup but once done correctly it works like a charm. Have not seen this program in a long time and I'm sorry to say that I do not have it anymore.
                    Good luck.
                    Bil
                    PS Newer versions of Sharpdesk allow you to acquire the MFP and scan that way. I've done it this way as well but with spotty results. If you have the setup disc for an MXM200 or even better an ARM207 I think the Sharpdesk I'm thinking of was included. LOL
                    • mincopier
                      • Dec 2015
                      • 289
                      Not a Sharp manufacture tech but I'll take a stab at this.
                      Chances are the computer is connected to the internet with the ethernet cable. This will in itself will prevent the copier from being plugged into the computer via ethernet so it is using USB for printing. Now to get around this the customer needs a 4-5 port workgroup switch or better yet a router. With the router this will separate the the local equipment from the internet. Let's go simple and use the workgroup switch. Unplug the ethernet from the computer and plug this into the switch. Plug a new cable into the computer and then the switch. Do the same with another cable from the copier to the switch. Now you have a small network. Set the print driver to print to the IP address of the copier and setup Scan desk. This should be less than $50 US Dollars. Not sure about Euro's.
                      • JR2ALTA
                        • Feb 2010
                        • 2030
                        If they're on the internet then have a network. Does any ISP not provide a router?
                        • tsbservice
                          Field tech
                          • 7955
                          Here we will just put second Network card in their PC(of course if there isn't switch or/router), and voila you are ready to setup network scan and print.
                          • JLSam
                            • Jun 2015
                            • 605
                            I... I like this... Yeah this might work. With the Ethernet cable that is.
