MX-C300W E7-11 Code
  • lgwilkinson
    • Nov 2016
    • 13
    MX-C300W E7-11 Code
    I am getting a E7-11 code as soon as the machine starts up. Thought it was white shading so I did a shading adjustment (sim 63-2) same problem so I did the sim to disable white shading (sim 7-1 item 7 changed to 1) still same. I checked all the connections same results. I am now thinking its the MFPC PWB. Is there any thing else that needs checked before i go and order a board. Appreciate any help. Sharp hotline was know help.
  • copiertec
    • Jan 2016
    • 2188
    Re: MX-C300W E7-11 Code
    Did you clean the mirrors and lens unit? Have you checked wall voltage? Is the copy lamp coming on? If so is it getting proper voltage?
