MX 3060N Phenix-Griffin
  • Smeden
    • Nov 2009
    • 15
    [Dead] MX 3060N Phenix-Griffin
    Machine dead, only the green led next to the powre button flashes.
    After 5 min the fusing fan starts.
    i've tried to repleace:Controller board, sd-card Msata, pcu board, HDD, DC powersupply.
    After i'v replace sd-card i could get into special boot. it said firmware mitchmatch because it has DSK kit.
    I'v reload firmware DSK everything looked fine "result ok" reboot machine, now dead again.
    anyone??
    Nothing is impossible for them who should not do it.
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: MX 3060N Phenix-Griffin
    Did you change the Memory? Bad memory can mimic a dead machine
    sigpic
    • copierdude1114
      • Dec 2015
      • 29
      Check to see if there is a paperclip on the board inside the doc feeder, sounds dumb, but it's happened to me twice.
      • fireater
        Repair God? not quite
        • Apr 2006
        • 253
        yup! me too. there is an update with a mylar to cover the big hole in the adf where they can get in
        I fix copiers ...Well Sorta
        • Smeden
          • Nov 2009
          • 15
          Thanks All.
          I'ts was the memory, but it have DSK kit. So vi have to get a new kit.
