Sharp developer MX-61GVCA
  • Trompeter
    • 38
    Due to the many problems with the cyan developer, we are eagerly looking for loose cyan developer MX61GVCA. Sharp has a number for it, but you can only order the MX61GVSA (all colors). We now have many loose Magenta and Yellow developer. Someone a tip how we can get a loose cyan developer MX-61GVCA?
  • bmwmick
    • Jul 2019
    • 27
    Re: Sharp developer MX-61GVCA
    Just fit the black dev set up as normal
    Be doing this for over 2 years
    No problems
    • fireater
      Repair God? not quite
      • Apr 2006
      • 253
      yup black dev works.. needs a few skyshots to get the colour right but it works.
      also use the mag and yellow same way.
      Clean chargers . install yellow or mag dev in cyan unit. balance dev with 25-2 as normal. run 100 partial skyshots to get the old colour out and the new toner will slowly change it to what you need
      I fix copiers ...Well Sorta
      • Mark_IBS
        • May 2012
        • 4
        What the heck! I never thought of doing that before. Will try this next time we get a colour dev pull.
        I've complained to Sharp for years regarding only being able to buy sets of colour dev. They always say "it's down to the factory", "it's marketing". It's a bloody rip off.
        • copiertec
          • Jan 2016
          • 2205
          $40.00 vs $500.00
          • lopakad1
            • Nov 2014
            • 69
            So what you're saying is put black developer in the colors run a bunch of sky shots after doing calibration and you get perfect color developer
            • woko
              • Jun 2017
              • 44
              I have done this little trick for the fist time this week and it works.
              • chubblies
                • Jun 2011
                • 154
                Yes this works. You can run process control and everything with black dev, as the sensors look for the coverage of toner rather than the colour. Run sky shots and after around 100 prints it will be the colour you want. Then run calibration etc to finish off.
                • leong.supertroni
                  • Aug 2015
                  • 13
                  No problems
                  Be doing this for over 10 years , start with Pastel 1 and C-jupiter 1
                  Sent from my MI MAX 2 using Tapatalk
                  • JLSam
                    • Jun 2015
                    • 605
                    Ill be honest, I've been doing this for 3 years since the initial post here on copytech. I told my boss who was skeptical. Once when we ran out of color DV packets, I asked if I can use this method, and was given the go ahead.
                    It worked.
                    My God he was ecstatic, he went home, did some calculations on savings for color DV and gave me a permanent raise.
                    Yes, I got a raise.
                    • hellcat
                      • Jan 2012
                      • 124
                      Any ideas on what is making the cyan DV pull? I loved hearing about this trick of using black developer but I am having an issue with an MX6070V dumping its developer almost weekly. We replaced C dv unit , c drum unit, MC board HV board and everything we can think of that might cause it to pull DV. It is still pulling developer.
                      Thanks for ANy Help.
                      • Trompeter
                        • 38
                        Hi Helicat, you changed the whole DV-unit for Cyan or only DV? We replaced a lot of detectors after issues with Cyan en Magenta.
                        • hellcat
                          • Jan 2012
                          • 124
                          yes we did change the developer unit (new one) out when it ran out of dv the 3rd time. yea this will be the 5th time in 2 months we've had to replace the cyan developer. Starting to hit the pocket book a bit.
                          When you talk about detector are you speaking of the atc Sensor?
                          • Trompeter
                            • 38
                            Yes, the RDTCT0248. But when you replaced the whole unit, this won't be the issue. I will look at it tomorrow and reply you later.
