MX6240 TB1 blade flip
  • woko
    • Jun 2017
    • 44
    Hello fellow Tech's. We have a primary transport belt unit that we exchange when we do a major service at a important client, however last week we exchanged the unit as normal, the next day the blade flipped, I replaced the blade with a new one set it up correctly with powder and today that ones flipped to, any idea what's going on. not had this sort of problem in years,
    Thanks Woko.
  • chubblies
    • Jun 2011
    • 154
    Re: MX6240 TB1 blade flip
    Thanks Woko.
    The cleaner box gets its drive from the belt, ie there is no direct drive to the box other than the belt. On the left hand transfer roller, there are springs on the front and rear that are against the roller to act as a brake. Basically remove these 2x springs so that the transfer roller runs freely, as the roller stalls otherwise and in turn stops the cleaner box from turning, eventually flipping the blade.
    • dsmith46
      • Oct 2016
      • 81
      Sharp had issued a bulletin back in 15' about the primary belt blade flipping. I personally do not rebuild these units anymore. It is more cost efficient to just replace the whole unit with a new one. Below is the bulletin:
      MFP-TB-1257
      Hope this helps!
      • woko
        • Jun 2017
        • 44
        , I will have a look
        • Hansen88
          • 1050
          I had one doing that not long ago and no matter what we did it kept happening. Did all the stuff from the bullitens ect. Then for the heck of it we bought that yellow patting powder. In a bulliten it said it is not just yellow toner. The box it comes in says yellow toner on it. I really think it is different because when I used it there was a lot less drag from the blade on the belt. It will probably flip tommorow for saying this but it has not flipped since.
