Sharp MX-3140n
  • wadezilla
    • Sep 2019
    • 3
    Sharp MX-3140n
    I disabled color mode and I need to know how to get it back. Original block to check for turning it off no longer Exist.
    Re: Sharp MX-3140n
    refer to your service manual for the process.
    • mansart
      • 852
      Re: Sharp MX-3140n
      How and where did you disable color mode. ???
      • wadezilla
        • Sep 2019
        • 3
        Re: Sharp MX-3140n
        Enable disable under system settings
        • mansart
          • 852
          Re: Sharp MX-3140n
          SIM 14
          • wadezilla
            • Sep 2019
            • 3
            Re: Sharp MX-3140n
            SIM 14
            Thank you so much. As many times as I have used sim 14, I would have never thought it would work. but it did
            • mansart
              • 852
              Re: Sharp MX-3140n
              To be quite honest I have never seen the option to disable color......have never looked either.
              The setting does not appear on all color machines. Does not show up on newer 70's &71s, nor does it show on the older 5001s
              Seems like it may have been a short lived idea.
              • Nachoman4life
                • Oct 2007
                • 212
                Re: Sharp MX-3140n
                Most color restrictions are done under the authority group.
                Where the heck is my spring hook?
                • mansart
                  • 852
                  Re: Sharp MX-3140n
                  This was not a restriction....it is a complete disable of color.
                  • chubblies
                    • Jun 2011
                    • 154
                    Re: Sharp MX-3140n
                    How do you enable it?? I didn't even know this was possible but it would be useful if there was an issue with colour somewhere
                    • mansart
                      • 852
                      Re: Sharp MX-3140n
                      Read the thread, all info there....
                      "system settings">"enable/disable"
                      Once color is disabled, the setting vanishes from "enable/disable"
                      To re enable color SIM 14
                      This option does not appear on all sharp color boxes.
                      I'm wondering if it would work in a "OUT OF YELLOW" toner scenerio.
                      • xring1958
                        • 166
                        Re: Sharp MX-3140n
                        I looked at a 3610 and did not see it I also looked at sim 14 in manual and did not see it there. Is this just some markets?
                        • mansart
                          • 852
                          Re: Sharp MX-3140n
                          This setting shows up in the MX2310 op manual.....MX2615 op manual....MX2616....MXxx40, MX5141 etc.
                          Apparently its been around for past few generations of color....Wonder if it works for "Down for color toner" scenerio?
                          Seems to have disappeared with the xx70's and beyond. Seems like a great troubleshooting tool as well as a way to "get them by"
