MX-M904 Finisher Jams in the Saddle Fold entrance area.
  • acribari
    • Aug 2015
    • 45
    Hello,
    I have posted here before when asking about this machine model and have since installed it at the customers location. The main body is New out of the box but the finisher FN-22 is used. It works fine in all modes except saddle fold / stitch. The customer programs the job for 8.5 X 11.0 paper saddle fold and stitch. 6 sheets of paper. It prints about 2 to 4 successfully and then jams at the top of the saddle entrance area. about 3 or so sheets of paper are stuck in there when I clear the jam. So I cleaned all the rollers and tried again. I get about 6 to 8 sets no problem and then it jams again.
    Could this be the foam rollers at the bottom? maybe a clutch or motor issue?
    Any clues on this would be great! I am new to Sharp models and need some help from an experienced tech.
    I do have another used finisher FN-22 to take parts from or swap out the entire saddle assembly. I don't really want to do that unless I can't figure out why its jamming.
    Thank you in advance.
  • dsmith46
    • Oct 2016
    • 81
    Re: MX-M904 Finisher Jams in the Saddle Fold entrance area.
    What is the jam code? Sharp issued a bulletin about the saddle roller sensor causing false jams, and ultimately change the sensor and mounting plate that it mounts to. It is bulletin: MFP-TB-1149
    • acribari
      • Aug 2015
      • 45
      I forgot what the code was. I will have to look when I go back. Stupid me... lol..
      the paper does actually jam. I will read the bulletin you posted but if it is actually jamming and I have to remove 3 sheets of paper it may not be a false jam. also, some times the paper does not jog properly and the stitch misses a sheet or two. so then it comes out with maybe two sheets skewed and the rest are jogged. I think its slipping somewhere. I will get the code.
      • acribari
        • Aug 2015
        • 45
        Sorry, this may sound stupid. I cant find the jam code for the saddle stitch folder jams. Where does it list the jams?
        They don't use the machine everyday for saddle. so I just now got a chance to go see them again.
        I am a noob on these Sharp machines and I know it sounds funny but I cant find the jam list. It does not display a jam code when it jams. Also it is not a ghost jam. It actually has 3 sheets of paper jammed in the top of the saddle stitch transport.
        Any help would be appreciated. Thank you and sorry for my lack of knowledge on this machine.
        • mansart
          • 852
          Print out a SIM 22-6
          P*C* 22 start
          6 start
          execute.....yes
          Scan and post the first page that prints out.
          • acribari
            • Aug 2015
            • 45
            I had the customer scan in the logs.
            They gave me all 6 pages. See the attached.
            Thanks again.
            • acribari
              • Aug 2015
              • 45
              Maybe FNS102_S and FSS203_N and FSS102_S
              • mansart
                • 852
                First thing I would do is firmware.
                According to bulletin below, there was a firmware upgrade to the FN22 to allow it to work with the M904.
                Because you started with a new machine and a used finisher, I would double check see that the firmware is most recent for both machine and finisher
                CCE1146-MFP-TB-751.pdf
                • acribari
                  • Aug 2015
                  • 45
                  ok, I have the new firmware so I will go back and try that first.
                  I will repost after. Thanks
                  • sharptech
                    • May 2011
                    • 40
                    You stated the FN22 was used. How many sheets of paper have gone throigh the finisher?
                    T.G.G.
                    • acribari
                      • Aug 2015
                      • 45
                      The finisher is used. I don't know exactly what you are asking but since its used there have been thousands of sheets through finisher. If you are just asking how many sheets make it when doing the saddle jobs then I can say that it completes about 4 to 6 books of 6 or 8 sheets fine and then it jams.
                      it only jams on saddle fold and stitch.
                      • OlliK1969
                        • Nov 2016
                        • 310
                        Hi
                        please control this part
                        0cwfc93369001 old number
                        0cwfc93369004 new number
                        Have had it broken at MX-M904 with MX-FN22
                        Parts manual MX-FN22 Section 21 ( Upper Feed Guide Assembly ) No.7
                        • acribari
                          • Aug 2015
                          • 45
                          I upgraded to the latest firmware. I still get the same finisher jams in the saddle entrance. 2 to 3 sheets usually are jammed at the top transport entrance area. I ran about 40 books and it jammed about 7 to 10 times. One or two of the books even came out of the finisher with the pages out of order.
                          Any other clues?
                          I did look at the paper feed rollers and assemblies and did not find any broken parts as per the last suggestion section 21, item 7.
                          If you know of any other things to try please let me know.
                          • mansart
                            • 852
                            I would start by swapping out the inlet sensor FSS201
                            If multiple pages are bunching up at Saddle inlet port roller, that would indicate .....
                            1. Roller is sometimes not being driven....is there a one way bearing in drive train of this roller?
                            2. paper is entering at an incorrect angle to hit the nip between inlet roller and mating guide roller....
                            • acribari
                              • Aug 2015
                              • 45
                              I replaced the sensor. I adjusted the solenoid for the entrance gate. Still jams. I found that the entrance plate on the saddle assembly was crooked a little bit. I loosened it up and re-mounted it properly. Also found the entrance are had a bent piece of guide plastic. I fixed that as well. Cleaned all the drive rollers from the top entrance all the way in to the folder.
                              Still jams.
                              I don't know what else to do except start replacing all the rollers etc...
                              So, I found another used finisher without the 3 hole punch and cutter. I may just take that one over and connect it just to get it running. The customer only needs saddle stitch and saddle fold.
                              If you have any ideas let me know. It may be something crazy like a bent frame or a warped shaft.
                              I will keep you all posted.
                              Thanks for all the help so far.
