Sharp MX -5070
  • TSS
    • Jul 2018
    • 27
    Sharp MX -5070
    i was getting TA code. I cleared,but when the copier comes to ready i get
    (Maintenance required.CodeIt will not clear.All the counters reset.
    Re: Sharp MX -5070
    what was the code #?
    did you replace the parts with the reset?
    did you follow service manual procedure?
    what did you EXACTLY reset?
    just to say you did it .. how do we know it was performed correctly?
    • TSS
      • Jul 2018
      • 27
      Re: Sharp MX -5070
      Copies were good so i reset Maintenance all.24-4 sim.When copier came back up,this was the exact messege.(Maintenance required.Code
      • tsbservice
        Field tech
        • 7962
        Re: Sharp MX -5070
        So, no parts replaced?
        • TSS
          • Jul 2018
          • 27
          Re: Sharp MX -5070
          Not sure why that smiley face comes up.icons are off.
          • TSS
            • Jul 2018
            • 27
            Re: Sharp MX -5070
            No
              Re: Sharp MX -5070
              BUT.....
              DID YOU REPLACE PARTS?
              sometimes you have to clear individual parts before clearing the counters
              and why would you clear counters if you hadn't replaced the parts? are you trying to: do a halfassed job? or do you feel the engineers that designed the unit and set maint part limits just are a bunch of fools?
              • copiertec
                • Jan 2016
                • 2188
                Re: Sharp MX -5070
                Do you know what the TA code means? Most of the time you clear this code their are other items that need to be changed. Do you have count on you maintenance items such as, black and color drum rotations? black or color developer rotations? How about you TK1 and TK2 counts? Possibly even fuser counts? We need a little more help here...counts would be nice.
                • NYPRNLA
                  • Sep 2015
                  • 21
                  Re: Sharp MX -5070
                  I dealt with this a while back when these first released. There was a bulletin about maintenance codes in regards to FK3 (web which these models do not have). If you have reset all codes it would seem this is the one you don't have access to in sim mode because it frankly doesn't exist.
                  Enter SIM Mode 55-1, select Switch Number 22, Data Number 6, and set to 0. Remember topress Execute before exiting the SIM Mode for the setting to become permanent.
                  This was also an issue on the new black and white MX-M machines as well which was fixed with a firmware upgrade.
                  So my recommendation is to upgrade firmware and then check and or change that soft switch.
                  • havokprod
                    • Oct 2012
                    • 159
                    Re: Sharp MX -5070
                    Isn't it Sim 55-3 ?
                    • Demon33
                      • Jan 2019
                      • 38
                      Re: Sharp MX -5070
                      I had the same problem on a MX-M3071 , there is no maintenance code it say " (maintenance : )"
                      I solved it by firmware update
                      Good luck
                      • doyvid
                        • Aug 2019
                        • 56
                        Re: Sharp MX -5070
                        You should never reset the drum or developer counters without changing parts. The machine uses them for its process control (to determine amounts of toner, voltages, etc) and you'll often get seemingly-unrelated trouble codes as a result, which can easily lead you down a rabbit hole of expensive unnecessary parts replacements.
