Sharp AR-M237
  • PhilinFla
    • Aug 2008
    • 13
    Sharp AR-M237
    Four machines in one location. Load originals in df, press start after a few seconds one of them will start to copy. The other 3 all wait until all the originals have fed in and then they start. Printed out the data sheets and compared them, all the same. Any thoughts/suggestions?
    Addon: Tried it in all 3 ouputs, non-sort, group and sort without any change
  • DavePo
    • Jul 2008
    • 303
    Sounds like the one is possibly set to group rather than sort.
      • 22864
      I was going to suggest face-up delivery versus face-down delivery, but I don't think that you can select for that on a Leopard (always face down). I like DavePo's answer better. =^..^=
      • costd
        • Jan 2008
        • 409
        SWAG
        Could be a memory issue.
        • CopierTechofOmens
          Agitating Artificer
          • 268
          * cough* andromeda *cough*
          sigpic
          • CopierTechofOmens
            Agitating Artificer
            • 268
            Is Mixed Originals set as the default?
            sigpic
              • 22864
              same effect.
              • The Otrain
                • 54
                Had the same problem. Mixed original detection is on for the ones that scan all originals first. You can turn it off and the machine will start copying instantly as it scans.
                • PhilinFla
                  • Aug 2008
                  • 13
                  Fixed
                  Thanks Omens and Otrain, it was the mixed original setting. Thanks to everyone elses suggestions.
