Sharp mxc 402
  • davebtech
    • Apr 2015
    • 170
    Sharp mxc 402
    Cust called and said colors are off.Green is light blue and red is purple.....? Any input thanks Dave
  • mansart
    • 852
    Re: Sharp mxc 402
    I would start off with cleaning and calibration.
    From there consumables depending on meter counts
    • Toner Boy
      • Aug 2007
      • 357
      Re: Sharp mxc 402
      Inspect DV units. These machines run dirty if not given parts at PM time. Contamination will suck DV out of units Serious cleaning and calibration.
      Optics are a bitch to clean, but if dirty calibration will be off.
      • mttech
        • Mar 2014
        • 127
        Re: Sharp mxc 402
        I agree with checking your consumables. From the description it sounds like you are missing yellow in the colors.
        • davebtech
          • Apr 2015
          • 170
          Re: Sharp mxc 402
          [QUOTE=Toner Boy;1101900]Inspect DV units. These machines run dirty if not given parts at PM time. Contamination will suck DV out of units Serious cleaning and calibration.
          Optics are a bitch to clean, but if dirty calibration will be off.[/QUOTE Printed calibration put it on glass but machine would not scan/calibrate print......says failed? Any input thanks Dave
          • spanky
            • Sep 2012
            • 468
            Re: Sharp mxc 402
            Run sim 64-5 and see of all of the colors are printing.
            If a color is missing or is not a solid, the calibration will not work.
            Must have good solids for calibration to work.
            If missing one color, then I would replace that dev. unit and drum.
            • davebtech
              • Apr 2015
              • 170
              Re: Sharp mxc 402
              Thanks headed in tomorrow with dvs and drums
              • davebtech
                • Apr 2015
                • 170
                Re: Sharp mxc 402
                Replaced All drums and developers and all is well, learned my lesson on this lease return sale.
                • copiertec
                  • Jan 2016
                  • 2186
                  Re: Sharp mxc 402
                  I bet it cost 4x's more to replace all drums and developing units than the machine is worth.
                  • davebtech
                    • Apr 2015
                    • 170
                    Re: Sharp mxc 402
                    Your going to drop 1300 supplies/machine and hopefully sell for 2500.
                    • copiertec
                      • Jan 2016
                      • 2186
                      Re: Sharp mxc 402
                      Hopefully your fuser is working good and lasts a while because if not that will also eat into your profit margin, another money sucker on these units.
