MX-Series Setting Up Accounts
  • Tech2002
    • Aug 2008
    • 334
    Want to set up Accounting - access to color & b & w on the machine. I know I can set-up Acct Codes from the Copier itself. I have done this. I am looking to turn off Color Access Only, using an Acct Code - but need to do this through the Web Browser. Does anyone know if there is a specific Set-Up Manual for this? I should know this, but I don't.
    Any direction on this would be appreciated.
  • NCArt
    Mountain Tech
    • May 2008
    • 81
    There are several steps you have to take, first by setting up your groups then setting up the defaults for that group. I have always gone through the web page to set up. You have to start in the user control area of the web page to set up your groups. In the MX, you should have all of the manuals available to you and while not really easy to set up, the manuals will guide you through the process. The manuals are found at the bottom of the web page on the left side.
    • Tech2002
      • Aug 2008
      • 334
      Thanks - greatly appreciated.
      Am I to understand that I can set up Accts within a Group and then, set up the Copier - as a walk up allow B&W Copying, and only have access to Color through Acct Codes?
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1885
        Which MX specifically are you talking about ?
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • Tech2002
          • Aug 2008
          • 334
          Sharp Model MX-2700N.
          • tmaged
            • Oct 2008
            • 1885
            There is usually a workaround.
            There was a one-time firmware update to do what you're looking for. I don't have it & don't think it's still out there. The new 2600 & 3100 do have walk up B&W with authentication for color.
            On the older machines, 2300/2700/3501/4501, the only way around it is to cancel the clear timer so it doesn't log you out. As Art said, set up your groups/users etc through the web page. It's pretty easy, common sense stuff. I usually set up a general B&W account with either all 00000 if they log in with numbers, or if they authenticate by username/password, call the account B&W and have no password on it. After you've canceled the clear timer, log in to the black & white account. Now anyone can make copies, only having to log out and then log in with their account if they want color. This works well as my experience is very few people actually make color copies, most are print jobs. The only caveat to this is users need to hit the CA key after they are done since we've canceled the clear timer. This was the only workaround I could figure out. Someone else may have a better one.
            Let me know if you have any questions.
            I assume you know how to set up authentication for color printing?
            Hope that helps !
            -Tony
            www.dtios.com
            • Tech2002
              • Aug 2008
              • 334
              I have not yet set up any accounting on this machine since we started installing them. If anyone was trained to do this it seems no one has a clear idea on how to get through it. So in answer to your last comment the answer is no. At least I have not set up any portion of this.
              When I set up the Authentication I did it in through the Copier itself. That is as far as I got. When I went into the Web Browser I was lost. But then I didn't have a lot of time to get through this so I told the client I'd be back to finish things for them.
              • NCArt
                Mountain Tech
                • May 2008
                • 81
                If you can access the user guides from the web page, it does take you through the steps to set up groups. It has been awhile since I set up groups, and have to use the manuals to refresh my memory.
                • tmaged
                  • Oct 2008
                  • 1885
                  you are correct, Sharp didn't do anything as far as training for setup on these machines. There are some videos on IDNCService now regarding these.
                  As far as printing goes, after you set up your users, you'll have to set their authentication code under the job handling tab. If they do not need color printing, set printing preference to B&W and leave the authent. blank. Any machine connected to print only needs authentication to print in color. If no authentication is entered, and you try to print in color, you'll hear the machine fire up but nothing will print.
                  You can also set batch printing so users can come up to the machine, select their name, enter in the password & release all jobs for them in one shot. It's a pretty nice function.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  • Tech2002
                    • Aug 2008
                    • 334
                    Thanks for your assistance - One And All!!!
                    I pride myself in keeping up with this information, but sometimes fall short - again, my thanks.
                    • OMD-227
                      Dont touch the 'special' firmware release that Tony is talking about. I have it if you need it, but the problem with it is, it cannot be upgraded. It is a one-off. Therefore, any firmware updates that are made for the machine to fix important issues cannot be used. You must stay with that same firmware release forever. It does work a treat though... infact, I have set it up on 2 machines 'as requested' and it seems to be working fine to this day. It works similar to the Whale series user authentication. The main problem is that it was released before the maintenance SNMP disable function (Switch 55-03, 9 bit 5), so your print spooler will continue to stop when any maintenance is due (unless you disable SNMP manually on the server).
                      Otherwise, everything the other guys said is spot on.
