MX-3140 Light Washy Copies (Print/Copy)
  • BigE
    • Nov 2019
    • 5
    MX-3140 has light copies and prints. Sim 64 test prints and Sim 46-74 calibration charts look dark and solid. The Images are always washy rather your coping or printing. Sometimes they don't look to bad but still washy. There is a darker wavey area on the trail edge most of the time. Any ideas? Pattern.pdfPattern1.pdfPattern2.pdfPattern3.pdf
    Re: MX-3140 Light Washy Copies (Print/Copy)
    Originally posted by BigE
    MX-3140 has light copies and prints. Sim 64 test prints and Sim 46-74 calibration charts look dark and solid. The Images are always washy rather your coping or printing. Sometimes they don't look to bad but still washy. There is a darker wavey area on the trail edge most of the time. Any ideas? [ATTACH]44489[/ATTACH][ATTACH]44490[/ATTACH][ATTACH]44491[/ATTACH][ATTACH]44492[/ATTACH]
    genuine OEM toners/drums?
    how old are the drums/dev units/fuser?
    who does maint on this unit?
    how many total copies on unit?
    which of the examples are copies or are they all prints?
    • JR2ALTA
      • Feb 2010
      • 2033
      Which one is the print? I see test charts being copied. Gradient color copies generally look like crap.
      • BigE
        • Nov 2019
        • 5
        Sorry my scanned copies are not that good. The first image (PatternPDF) is generated from Sim 64. The actual image has solid colors. Pattern1PDF & Pattern2PDF are copies to show that they are light and washy. They also show the dark wavy area on 1 side of the copy. Also the 2 copies show how one time its very light and then its a little better without doing anything. Pattern3PDF is from color calibrating Sim 46-74. This original image also is solid. I dont understand way my copies and print are light and washy when anything generated from the copier engine looks good. I did not include a print image as they look the same as copies. New DV. Drums, Transfer belts and fuser not very old.
        • tek tevee
          • Jan 2020
          • 6
          check Toner Save Mode maybe ON. Uncheck the box of the toner save mode.
          • guitar9199
            • Sep 2016
            • 1100
            OK... If your PRINTED images look dark and crisp, but your COPIES look washed out, first thing to look into are your optics. If you have dust on the mirrors/lens/lamp, it won't produce enough light for the laser to give you a solid image on the drums.
            • BigE
              • Nov 2019
              • 5
              OK.... So Im new here. Working on copiers for 30 years. Been working sometime now for a small business with limited resources. Was hoping this site could give me some help. So please tell me how do I need to describe my problem? I thought I was clear that the PRINTS & COPIES are washy and light. The engine generated images (i.e.Simulation 64) look good and solid. Also there is a DACKER area on the side of the page(prints & copies). The dark area is not on the engine tests. THANKS EVERYONE FOR YOUR HELP.
              • jp74msj55
                • Oct 2014
                • 151
                Looks like your Yellow or Magenta developer is depleted to me on your 3rd example.
                • JLSam
                  • Jun 2015
                  • 605
                  I don't know if OP has resolved the issue or not, but I have experienced this issue many times on this family in general.
                  It would be nice if you posted the 22-6 print out, and your answers would have been better. In your pictures posted, it looks to me that you need fresh developer.
                  Also, you need to do the FULL CALIBRATION stated in the Service Manual. Remember to do so after every change of developer or drums. You can clearly see that your halftones are off, no wonder you have light copies and prints.
                  After replacement and service, your routine should look something like this:
                  Clean IDS and OPTICS (Scanner and LSU) then perform Sim 50-22 (Follow instructions) / 44-2/ 44-6/ 44-27/ 44-26/ 61-13/ Reboot/ 61-11 (Light, Medium, Dark)/ Reboot/ Sim 46-74/ 64-5 for test.
                  Also please see:
                  Bulletin TT-100314_2
                  1. Check laser skew and color registration in Sims 50-2 and Sim 61-4.
                  2. Clear the auto and manual correction values in Sim 61-13.
                  3. Enter Sim 61-11 to run the laser power auto correction in the order of Light -> Middle -> Dark. Follow the screen instructions carefully. Note, SIM 6-11 is ADJ-22 in the MX-6240N /MX-7040N Service Manual and ADJ 10 in the MX-4140 / MX-5140 / MX-4141N / MX-5141N / MX-4140N / MX-5141N Service Manual. Refer to the respective Service Manual for additional Adjustment information
                  4. Check the image quality. If the result is not satisfactory, repeat step 3 again.
                  5. Run 64-74 to adjust the color balance
                  ​Good luck.
                  • repn1999
                    • May 2010
                    • 310
                    for what its worth....check to make sure the exposure settings for copy and print modes are on factory defaults and then recalibrate. I have actually had a tech with a similar issue who did a complete pm and still did not resolve the issue and it ended up being someone set the exposures to max for both print and copy which caused the machine to not calibrate properly. just something i see overlooked alot.
                    • BigE
                      • Nov 2019
                      • 5
                      Tech went to customer's office yesterday. We did a data default reset(Setting_Secuity Settings_Initialize Private Data/Data In Machine). After that the copier is working. No more light copies with the darker area on the side of the copy. Tech did not check if the toner save mode was on. While talking with the customer she does recall doing something with toner save. Thank you tek tevee and repn1999 for reminding me you never know what the customer has done. Thanks to everyone for your help
                      Still a little baffled on why it had the dark edge.
                      • jon jennings
                        • Aug 2011
                        • 51
                        Have you tried cleaning the density sensors? If the density sensors is reading through a dirty glass or if it has one of the swing arms on it with a dirty patch that will cause this exact problem. Clean the sensors and run 44-02 44-27 44-06 44-26 and 46-74 in that order.
