phoenix/griffin mfps mx-3050, 3070, 3550, 3570, 4050, 4070, 5050, 5070, 6050...
  • Sage632
    • Jul 2019
    • 45
    Re: phoenix/griffin mfps mx-3050, 3070, 3550, 3570, 4050, 4070, 5050, 5070, 6050...
    Update...
    So sharp had originally told us to change the paper weight settings to 16-28 lbs in device control.
    This made the problem worse.
    Current orders are to reduce fusing heat -5 or -10.
    This does not seem to work that well, though...
    • bigdaddyooo
      • Dec 2014
      • 212
      The 50-28 is no longer on these models. In setup, you HAVE TO do a 50-10. Very simple.
      The bulletin tt-070918_1 states how to check temp offset.
      I set up all the machines for my company and during setup of these models I do a 50-10 and 43-1 as follows, fuser temp level to -10 then fuser condition adj setting to default, then under system settings to common settings to device control, the plain paper setting is set for 16-23 lb paper. almost no curl occurs. I have had to lower the inlet guide plate to lowest max to insure the paper goes straight to the roller belt nip area and NOT at an angle. hope this helps
      Are you the police? "No ma'am, were musicians"
      • Sage632
        • Jul 2019
        • 45
        Will try this as well... Thanks!
        • sharptech
          • May 2011
          • 40
          #19
          I would make the lead edge and trail edge voids 1mm larger than what the manual says. Remember the trail edge of the first side becomes the lead edge of the second side when duplexing.
          T.G.G.
          • Sage632
            • Jul 2019
            • 45
            #20
            T.G.G.
            I have tried this. Once it starts wrapping, even the cleaning page will wrap which has a massive gap on the first side and no printing on the second side...
            • what_moustache
              • Jan 2015
              • 15
              #21
              • SharpSwe
                • Sep 2019
                • 11
                #22
                Hi.
                I'm not sure I've seen this issue, and not sure if this will help. But try this if you can.
                On the Fusing unit, under it where the paper enters. There's a guiding metal plate than can be loosened by 2 screws. Making the gap abit larger for the paper to go through into the fusing unit. Make it larger and then fix the screws again.
                Adding picture
                • Sage632
                  • Jul 2019
                  • 45
                  #23
                  Originally posted by SharpSwe
                  Hi.
                  Adding picture
                  [ATTACH=CONFIG]45133[/ATTACH]
                  We will try this,
                  But I don't see how that could prevent paper sticking to the pressure roller on the second pass
                  • SharpSwe
                    • Sep 2019
                    • 11
                    #24
                    Originally posted by Sage632
                    We will try this,
                    I agree. I do however seen paper jam only caused during duplex with very weird results. This is one that helped.
                    And what previous users have said. The fusing units on these models could be better.
                    If you can, maybe switch out a fusing unit from a working machine just to rule it out.
                    • SharpSwe
                      • Sep 2019
                      • 11
                      #25
                      Need to ask also. What kind of prints is it that gets jammed?
                      Is it fully covered papers all the way to the edges?
                      And
                      By Wrap. do you mean a sudden stop or that the paper gets stuck on the roller and wraps AROUND the roller?
                      If it's the latter. We've had issues on some that we had to install a Cleaner Roller and a Seperation Unit cause of very covered prints causing the fuser to becoming sticky.
                      Parts:
                      ⦁ CFRM-1766DS53 (Lower Separate Unit)
                      ⦁ DUNT-9555DSZZ (Cl roller Unit)
                      Adding technical reports.
                      • mansart
                        • 855
                        #26
                        Mmmm....can't find those bulletins on the U.S. side
                        • Sage632
                          • Jul 2019
                          • 45
                          #27
                          And
                          Parts:
                          The print wraps around the pressure roller on the second pass.
                          The it is usually a duplex flyer of some sort with heavy print. Not always full page. But will usually have some sort of heavy fill area on the page.
                          I think it is due to no cleaning web (or roller) and no stripper pawls on the lower roller.
                          It has nothing to do with the lead edge or the trailing edge. Once it starts wrapping, even cleaning pages will wrap (the lead and traing edges on those several inches)
                          • mansart
                            • 855
                            #28
                            the cleaning roller kit mentioned above by SharpSwe, seems to be available as a part for the Sharp USA market, just no tech info
                            • SharpSwe
                              • Sep 2019
                              • 11
                              #29
                              Then I would check in with Sharp Tech Support there in US to see if possible to get a hold of a Cleaning kit. But I believe the damage has already been done on the pressure roller once it's started wrapping the paper.
                              • Sage632
                                • Jul 2019
                                • 45
                                #30
                                And
                                Parts:
                                My parts guy says he cant find CFRM-1766DS53
                                Also are there any other parts associated with the cl roller unit (ie. Motor, bearings, etc.)?
