SHARP AR-6020 Error E7,10 - Black Copy
  • noobtech
    • Jul 2025
    [Error Code] SHARP AR-6020 Error E7,10 - Black Copy
    AR-6020 seems to be a troublesome machine, series of errors now and then.
    E7,10 Error shows, check and cleaned everything, error persisted, then after SIM-14, Errors clears, machine takes forever to be ready on its own, but if forced to be ready, Machine copy complete BLACK.
    Anyone experience this before? I need help. What can I do?
  • GIUBOSS
    • 1436
    Re: SHARP AR-6020 Error E7,10 - Black Copy
    Description: Shading problems (black correction). The scan level of the CCD black is abnormal during shading.
    Causes: Incorrect connection of the flat cable of the CCD unit. Fault of the CCD unit. Fault of the MCB PWB.
    Solution: Check the flat cable connection of the CCD unit. Check the CCD unit
    • GIUBOSS
      • 1436
      all black copy, did you also print from pc or internal test?
