E6-11 MX 4141
  • xring1958
    • 166
    E6-11 MX 4141
  • driving lots of miles
    • Jun 2016
    • 397
    Re: E6-11 MX 4141
    Yes, the
    White reference plate on the front underside of the slit glass.
    • Prints Charming
      • Aug 2019
      • 189
      Re: E6-11 MX 4141
      I've seen a few things cause E6-11 on the DSPF models.
      - Dirty optics
      - Staple or clip fallen down onto the DSPF controller board
      - A DSPF constantly slammed closed causing damage to the CCD & Mirror Lens
      First, check your copy lamps are working in sim 5. You'll need to take the back cover off the DSPF to properly see the lamp activating. It should stay on for a few seconds during the test, flashing a few times during a sequence. This is normal. If you don't have a DSPF lamp activating, you most likely have a problem with the DSPF Inverter board or lamp itself.
      Next, check the values in 63-01. You'll see numerous values for DSPF. These should have numbers in them. If they do....great.....but if they're all 0 (and the copy lamp is working), you have narrowed the problem down to the DSPF controller board or the CCD Unit. You'll see a value for DSPF Trouble Code R, G, B. These should be 0 when everything is working. If you see a number for this value, refer to the service manual for sim 63-01. A working CCD Unit, Lamp and DSPF controller will have Error Code 0, with numbers for all other DSPF values.
      Lastly, you're definitely going to need to run the DSPF Shading Adjustment with the Shading Sheet (UKOG-0333FCZZ) to reset the DSPF values to normal.
      If your lamps are working, and you have values in 63-01, then you might just need the Shading Sheet adjustment performed. This is common when the device is frequently in direct sunlight and the shading values go out of range. Have seen it many times!
      • xring1958
        • 166
        Re: E6-11 MX 4141
        Originally posted by driving lots of miles
        Yes, the
        Wouldn't it be nice if they showed it in service manual and did't call it white mylar in parts Manual?
        Thanks for the cofirmation
        • xring1958
          • 166
          Re: E6-11 MX 4141
          Thanks for the info Prints Charming
          We brought the machine in.
          I cleaned optics checked Copy lamps ( Both Work ) In 63-01 OC had 1 error code and has values DSPF had 0 error code and has values.
          I replaced the CCD Board in machine & the SCU PWB. I didn't have the Shading sheet but ordered it.
          Any further guidance is always appreciated
          • repn1999
            • May 2010
            • 310
            Re: E6-11 MX 4141
            there is an old style and new style ccd and scu board. you need to make sure you have new with new or old with old. old with new will not resolve the issue and will give you codes you cannot resolve.
