Sharp AR-M355
  • GottaFixEmAll
    • Jun 2007
    • 55
    Sharp AR-M355
    As mentioned in my previous post ... I have one of these, it has the scanner enabled ... but I don't have the SharpDesk software ( I got it from Paramount Imaging ) and understand that the software is licensed to the original purchaser ....
    I either need to find a copy of the Sharpdesk software or find out what steps are used to set up Scan to E-mail ( which was suggested by CopierTechOfOmens ) --- I think I have to set up the Pop and SMTP parts, Ie: smtp.Charter.net ( My internet service provider )
    I work on quite a few of these and a lot of Sharps in general over the years ... but I have never set one up to Scan !!!
    Also, what is teh best way to set up printing ???
    Thanks, Mike @ Michael's Copier
  • MHeon71
    • Oct 2008
    • 489
    Printing, I prefer to go set up on the server, but seting up to print from individual PCs is fine. Scanning, you do need the the SMTP and POP3. SMTP could be right and the POP3 may be the same as SMTP, except it might be mail.charter.net. I setup the DNS and other stuff like that which you can find by going to the DOS prompt and typing IPCONFIG /ALL. This should give you all or most of the info you need.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      Mike, if you're a Sharp dealer Sharpdesk is available for download off the IDNC Service site. It's the easiest way to do it, unless you know what you're doing. I think that model has authentication for email. The previous model did not. It does not support SSL and places are starting to use it for email. MHeon is correct, you'll need a DNS server to resolve the name mail.charter.net. Or you can Ping mail.charter.net & it will reply with the correct IP address. The only problem in doing it with IP address is if the address changes you'll have to go back & change the IP address.
      LMK if you need help or have any questions.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Comingapart
        • Jun 2008
        • 44
        You won't need Sharpdesk for Email scanning.
        Access the imager webpage and input the smtp server info in the proper boxes.
        If the mail server allows anon access, then you're golden, if i requires authentication( almost all do) then you will need to work with IT/mail hosting company to setup a proper account for the machine to use.
