MX-M3070 Weak solids.
  • xring1958
    • 166
    [CQ] MX-M3070 Weak solids.
    We have a MX-M3070 with about 120K copies on it we recently replaced the Drum and later the Developer. Tech noticed Mag roller was very discolored with a dark Grey coating, Many years ago we had a similar issue with the Panasonic DP-2500 a mono component machine. We found that if we cleaned the roller with solvent it would resolve the density issue. This is the first time we have seen a Dual component developer machine. We are planning on replacing the unit but was wondering if any of you have seen this issue.
  • copiertec
    • Jan 2016
    • 2198
    Re: MX-M3070 Weak solids.
    If it is not one of the updated developing units, do not waste your time, just order the updated one. Many issues and updated units.
    • mojorolla
      The Wolf
      • 2604
      Trying running laser power adjustment after the normal calibrations, 61-11
