Sharp MX3640 fuser noise
  • repn1999
    • May 2010
    • 310
  • copiertec
    • Jan 2016
    • 2207
    Re: Sharp MX3640 fuser noise
    I see where you have installed new fuser units and tech bulletins concerning this issue.1.) I ask this just to confirm, with those new fuser units, are they the latest units from Sharp with the updated fuser web assembly with all the updates applied? as well as the updated routing of the fuser web, etc? 2.) Is the client running full bleed prints?
    • repn1999
      • May 2010
      • 310
      They are brand new units from sharp and they have been tested in other machines where they work fine. Client runs health care type forms and no bleed to speak of just mostly bw text. Very rarely even uses color at all.
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        Try a registration clutch change. it happened to me once. An apparent screeching from the fuser turned out to be the registration clutch oxid buildup.
        My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
        • Hansen88
          • 1068
          The company I work for uses generic toner,it sucks and creats many problems but they still think the cheaper price is better. We had a couple machines doing this same thing. When we switched those customers to oem toner the problem went away.
